Ca18det crank question
From Goulburn NSW
Hi guys I have a question about the gilmor type pully that is on the crank behind the harmic balancer for the timing belt.Does it just slide on and off using a key?
Posted on: 2014/3/25 7:53
Re: Ca18det crank question
From Sydney
Yes, they tend to seize on over time and In some cases will need to be destroyed to get them off. ( you can still get them new from Nissan )
Posted on: 2014/3/25 8:17
heat them up and they come off with a bunnings plummer propane torch thats how mine came off, nothing special but new is good too. Arent you using a new stroker crank?
Posted on: 2014/3/25 13:41
From Goulburn NSW
Yes D im using a spool stroker crank,when I get the bottom end built ill get them to take it of and put on the new crank.
Posted on: 2014/3/26 0:24
Best get a new one then
Posted on: 2014/3/26 13:21
From Goulburn NSW
Does anyone know the official name for this item?
Posted on: 2014/3/26 23:43
From Brisbane
It'll be something along the line of cam belt drive gear - http://www.ebay.com.au/itm/Nissan-130 ... -Silvia-New-/201056006403
Posted on: 2014/3/27 1:06
