Re: A10 - A12 oil pan?
Heya Maik can you take a pic of your sump
Im pretty sure its the same for the A14 fwd engine found in most markets
if not you might have to get the A14 version instead but otherwise you
would just put the block that you want if your in luck.
Nissan interchanged alot but I would think the A15 wont be possible due
to the sides of the sump needing clearance due to biggest stroke.
Posted on: 2014/4/22 8:49
Subject Poster Date
     A10 - A12 oil pan? MaikCherry 2014/4/22 8:38
       Re: A10 - A12 oil pan? D 2014/4/22 8:49
       Re: A10 - A12 oil pan? ddgonzal 2014/4/22 8:54
       Re: A10 - A12 oil pan? MaikCherry 2014/4/22 10:16
