B210 FS5W63A into B310
Not too shy to talk
Hi my friends.
I have found local an fs5w63a gearbox from b210 datsun.
I would like to put in B310 can any tell me ALL modifications required to put into b310 such as if prop shaft needs changing or xmember needs fabricating.
Thanks
Posted on: 2014/4/27 23:39
Re: B210 FS5W63A into B310
1. Get the matching drive shaft from B210
2. Get the special clutch disc from B210
3. Gearbox cross member needs modification. The B310 automatic crossmember is likely the closest and has the right rubber insulator.
4. If your B310 has cable-operated clutch, convert it to hydraulic operated (master, pedal, and line).
Posted on: 2014/4/28 0:19
Not too shy to talk
Ok
Clutch disc do you mean clutch plate it self?
How do I tell if clutch is cable or hydraulic?
Thanks I am new to all this
Posted on: 2014/4/28 0:30
Re: Clutch disc for FS5W63A
Clutch disc is specific to the 63
Clutch pressure plate (clutch cover) is the same as the 4-speeds
Posted on: 2014/4/28 1:35
Edited by ddgonzal on 2014/4/28 2:20:19
Edited by ddgonzal on 2014/4/28 2:50:55
Re: How do I tell if clutch is cable or hydraulic?
Look in the engine compartment, on the driver's side.
Hydraulic clutch will have a small master cylinder next to the brake master cylinder.
The FSW63A transmissions are all hydraulicly operated as I understand.
Posted on: 2014/4/28 2:57
Not too shy to talk
Thanks,
Last question - Does the FS5W60L or FS5W60A use a hydraulic clutch?
Posted on: 2014/4/28 13:07
The FS5W60L and FS5W60A can use either hydraulic or cable clutch.
Posted on: 2014/4/28 17:43
