Threading problem
Quite a regular
From Melbourne VIC
Went to tighten the nut on my steering column this arvo and with barely any pressure I start seeing metal shavings coming out. Now my steering wheel is completely loose and the nut isn't tightening down.
Is this a nut thread or steering thread problem?
Need to move the car back into the garage but can't change directions
Posted on: 2014/6/8 3:37
Re: Threading problem
Take a close look you will see if the nut or the column thread has stripped.
Posted on: 2014/6/8 3:59
If it was already tightened to maximum safe torque,, tightening it more will damage it.
Just fit a new nut on to it. Tighten until the washer compresses, no more.
Posted on: 2014/6/8 4:15
From Sydney Australia
And use Loctite to make sure it does not come loose , But make sure there is some thread viable to actually hold the steering wheel on with, It is not funny if it comes off in your hand while driving.
Posted on: 2014/6/9 1:07
Quite a regular
From Melbourne VIC
So I got a new nut and that works like a charm. Problem now is that the column threading is damaged. What size do I need to rethread this problem? Really need a reply asap as i'm selling the car on the weekend
jpg  10416780_321585597994755_225309175_n.jpg (46.55 KB)
17735_5399807bcf2b0.jpg 720X960 px
Posted on: 2014/6/12 11:26
The same as the new nut you bought
Posted on: 2014/6/12 15:30
Car free
Run a tap over those threads to clean them up. Do it carefully.
Posted on: 2014/6/12 19:19
