Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#11
Re: Difficult starting in cold weather
Posted on: 2014/5/31 6:45
Nope im not sure- im 10,000kms away. Dd is half way round the world.
if in doubt seek professional assistance but you say starts and drives fine with a jump. So I suspect battery is old and low on cranking amps. Get a higher cranking battery. If thrres other carb issues????
#12
davem69
Posted on: 2014/5/31 22:59
And maybe a A15 starter motor on a A12 goes great
#13
Posted on: 2014/5/31 23:15
Whats that got to do with this?? It should fit.
#14
davem69
Posted on: 2014/6/2 22:54
Kick,s it over a lot faster couldn't hurt
#15
Posted on: 2014/6/2 23:07
Also needs more cranking amps to spin it.
I always thought the starters were the same.
#16
Posted on: 2014/6/3 22:36
About a half dozen different starters.
Auto starters are more powerful but run slower Early starters are not as strong as later A15 & A12 sunny use the same starter.
#17
RigerZ
Posted on: 2014/6/9 13:40
My thinking was if the carb was getting a bit iffy the air/fuel mix in cold weather wont be right, thus the difficult/no starting.
#18
Posted on: 2014/6/9 21:37
The a/f ratio is never right when cold, but either the choke or pumping excess fuel will make it close enough to start.
If it starts quickly when jump-started, you need a new battery. I have seen that many times.
#19
RigerZ
Posted on: 2014/6/10 16:02
even so the choke/pumping technique should do it, even at times when the cranking was reasonably strong
#20
Posted on: 2014/6/10 21:14
It will always start faster after an Engine Tune-up
