« 1 (2) 3 4 5 ... 8 »
Re: mikuni bike carb help needed
posted by sikyne on 5/15 12:07 GMT
Another way around it would be to use a small ally swirl pot.
Mount it high on the firewall, pump from the stock pump into the top and have a return going from the pot pack to the tank. Use the bottom fitting to gravity feed the carbs. It would only have to be the size of a cigarette packet.
Posted on: 2014/6/27 9:25
posted by unfamilia on 5/15 15:15 GMT
im not sure how it may be fuel pressure when its only on 1 carb out of 4????? All other 3 cYls running fine no leaks
Posted on: 2014/6/27 9:26
posted by ddgonzal on 5/15 21:56 GMT
When the fuel pressure is slightly excessive, not every inlet needle&seat will leak.
posted by sikyne on 5/15 23:06 GMT
As an experiment, just suspend a 1 liter container for fuel with tie wire from the open bonnet to feed the carbs. If the flooding goes away, what I suggested on the earlier post will fix it.
As DD said, its not uncommon for only one or two needle/seats to leek with pressure too high.
I believe the bike carbs are gravity feed on the bike. So the pressure would be way under 1 psi.
Posted on: 2014/6/27 9:27
posted by unfamilia on 5/15 23:29 GMT
Will try tomorrow. I hope it works.
Dont have a return line to tank for a swirl pot set up unfortunately unless breather lines can be used
posted by D on 5/15 23:32 GMT
I had a rubic's cube sized gravity fed tank sitting higher than the carbs on the firewall never bothered with fuel regulator from the start due to bike gurus advice.
posted by unfamilia on 5/16 1:00 GMT
Where to get a tank for the firewall?
Posted on: 2014/6/27 9:28
posted by unfamilia on 5/16 4:19 GMT
That passage is the main airjet passage.
So its either float level, sticky or leaky float, needle and seat not sealing or too much pressure.
im tempted to swap floats in cyl 1 and 2 to see if the problem swaps too. Will help narrow down issue
Posted on: 2014/6/27 9:29
posted by benny on 5/16 4:33 GMT
Path of least resistence
posted by unfamilia on 5/16 5:28 GMT
Will see I guess.
Posted on: 2014/6/27 9:30
