posted by
unfamilia on 6/24 14:24 GMT
Ok reading old hotrodders forums etc. The fuel pressure reg gaugr will fluctuate from 0 to the upper limit that the fuel pressure is set at at idle. In my case I can get from 0 to 2 or 2.5 or 3psi flickers. Once reved to about 2000 rpm it shiws the steady level of pressure, in my case 1psi. The fluctuation or flicker is cause im using the mechanical fuel pump. I didnt think about that and as it runs off the cam, it only pushes every full rotation of the cam. So full 2psi to 0 and tgen to 2psi. The fuel the carb doesnt need is bleeding off the t past the one way valve on its journey back to the tank. WIN! I think I have actually got this now.
Some setups use the fpr on the return side of the feed to keep pressure in the carb fuel line (typixally old fords and chev big blocks needing 6-8psi). As carbs only need approx 1psi or less I think my methods ok as im not regulating 4.5psi into return line from stock pump hoping the needle and seat hold it back (which I know now from previous posts they don't like more than 0.5-1.5 psi).
Long term driving real world can begin once I mod a new throttle cable holder for the rocker cover. Whoever said zip ties ftw got it wrong
