« 1 (2)
Re: Seam welding a sedan
From Sydney NSW
You'd think that.. but theres a few wack of paint, and old sealer to remove so would be more than a day(the sealer almost looks like Tar)
Posted on: 2014/6/29 7:40
There maybe faster ways to go...
But I'm never in a rush
From Sydney Australia
Go here and download this for a start as the chassis section will basically tell you what you need to know.
https://docs.google.com/uc?id=0ByCvxnH ... ZLd1V0Q3c&export=download
Found here thanks to Dime Quarterly.
http://dimequarterly.blogspot.com.au/ ... o-modifyand-digitize.html
This is a digitised varsion of the old How to Modify datsun 510 (1600) Engine and Chassis but the chassis bit is applicable to a 1200.
A few pointers seam weld the chassis rails, Diagonally brace the upper cantrail (the upper rail the guards bolt on to) where it meets the A Pillar (the vertical section the front doors hinge off) and most importantly find a 1200 photo with a Roll cage fitted and work out where the Roll cage will eventually mount and then plate that area with at least 2 mm ~2.5 mm sheet metal across the floor pan and up across the inner side of the inner sill panel to give a strengthened area where the main legs of the Roll cage will eventually mount.
Same for the front legs where they will sit on the front floor and again on the rear parcel shelf where the rear legs of the cage will eventually sit and remember that at the rear parcel shelf area you really need to continue the cage down under the rear parcel shelf to pickup on the rear chassis rails.
If you do this plating before it is needed you can then bolt in a Roll cage onto an already reinforced section ready to go when needed, Otherwise you face the risk of upending the car and seeing the Roll cage legs punched straight through the floor where they mount and I have seen that happen as most cages only use a relatively small section for the mounting plate usually 5 mm thickness and about 100 mm x 70 mm size wise at best which is OK if it bolts to an already reinforced section, But not big enough for a major roll hence reinforce the shell where the cage will mount, The total area for the Main Hoop mount ends up being about a square foot in area to spread the load over a large enough area to work properly
Posted on: 2014/7/2 21:58
« 1 (2)
