a14gx
From Kelmscott Western Australia
Not that long ago i had a a14gx engine for sale
It wasent sold due to the fact apparetly theres no such thing
BUT i have just found IN JAPANESE a hard copy book that has a photo and it says A14GX
So is there no such thing well if you still dont believe
Ill post the photos up when im next to a computer next
Posted on: 2014/7/30 1:06
Re: a14gx
From Brisbane, Australia
1400GX had the A14T engine. The thing people call GX engines are the A12T with the rare big port head, twin outlet exhaust, pre-pollution Hitachis and a couple of other bits and pieces. It's the rarity of those parts that make it worth something. None of those good, rare parts are in the A14T. And It wasn't worth $1800.
It's like taking a 120Y bonnet and advertising it as a GX bonnet because it's off a "1400GX" model. There is nothing special about a 1400GX bonnet, and there is nothing special about the 1400GX engine, apart from the relatively common 38mm hitachi carbs shared with the L series engines.
Posted on: 2014/7/30 3:00
Re: a14gx
From South East Brisbane
Re-quoting for emphasis.
Posted on: 2014/7/30 7:07
datsunikon (fb) | datsunikon (blog)
Re: a14gx
From melbourne
A genuine 14GX ?? Doubt it... And Im pretty sure its just an A14T. As I recall , there was no A14GX built, its just what we called it here Down Under. $1800 for that unicorn... Pleaseee listen to the experts, its a horse in drag !!
Posted on: 2014/7/30 8:54
Re: a14gx
From vancouver, wa. usa
(Caps lock engaged) WHERES THE PICTURES! not that it matters. You could post pictures of the carbs, should be 3 bolt filter flange triangle pattern. If it was an a14t. Probably just sus on a stock 1.4, whats the head casting? Whats the exaust manifold look like?
Posted on: 2014/7/31 8:30
72, 1200 coupe
77, 710 2 door sedan
Re: a14gx
Im running an a14 with sss 510 su carbs, I like it alot. Great motor, only bad thing about them (if your selling it) is the price.
Around here ( northwest usa) an a14 is cheap, couple hundred bucks, 3 maybe 5 for a verry good example, the su carbs are 100-300$ used, a series su manifold are scarce, but around. 100$ can usualy get one.
No one saying your motor isnt good, great combo, but its not a "race motor" such as a gx, wich got closed chamber big port heads, 4 into 2 exaust manifolds, su carbs are just another thing they got. Not the only thing.
Posted on: 2014/7/31 8:38
72, 1200 coupe
Re: a14gx
Save your breath guys its his mate selling it and so wont listen to reason most likely. Its got to be a gx cause its worth $1600 and a book says its exists. I belive in unicorns too cause I saw them in a book
Posted on: 2014/7/31 10:00
Re: a14gx
he posted the pic of this book on FB (bottom photo). It does not say A14GX. It says 1400GX.
The 1400GX model came with A14S or A14T engines. You could just as accurately sell a single carb A14 as an A14gx engine
jpg  1654297_590834267703084_1464814660086781029_n.jpg (14.90 KB)
518_53da11110457f.jpg 480X360 px
Posted on: 2014/7/31 10:39
Re: a14gx
Interested to see this photo, I never knew they existed. What page number in the manual does it show the A14GX?
Posted on: 2014/8/2 20:35
