#11 Re: Bad vibration A15 when reved
dato1200-83 Posted on: 2014/7/29 2:40
That should have said pulled an L20 apart
#12 Re: Bad vibration A15 when reved
b310gx Posted on: 2014/7/31 11:43
Could be a badly balanced flywheel, all the way through to a cracked crank (bought one of those once). Or maybe the clutch plate is worn badly or it's the pressure plate. Hopefully for you it's an accessory like an alternator bearing, or a broken mounting bolt you just haven't found yet, like the alternator bolts.
#13 Re: Bad vibration A15 when reved
shane0o7 Posted on: 2014/8/7 7:45
Has to be internal on motor. As I have started motor up with clutch and pressure plate removed and fan belt removed and free reving the motor still has vibration.
#14 Re: Bad vibration A15 when reved
Posted on: 2014/8/7 8:06
Could be out of balance flywheel
#15 Re: Bad vibration A15 when reved
anths Posted on: 2014/8/8 1:40
Have you checked compression and valve clearance and that all spark plugs are firing...?
« 1 (2)
