Nissan/Datsun Pulsar ET Turbo Mags
Quite a regular
I don't know if any of you out there actually read my question on these mags but i still would like some info. As i said, i have seen them on a Datsun Sunny and my question was, Do they
fit on standard 1200 struts? The ET Pulsar is front wheel drive and i was just wondering if they would have enough clearance on the front strut (on the inside of the tyre against the
strut and would they have enough clearance on the rear, on the inside of the tyre (does it rub against the body).
Has anyone ever put these rims on a 1200 before?
Posted on: 2001/10/18 8:44
Re: Nissan/Datsun Pulsar ET Turbo Mags
Ive seen those ET turbo mags used on a 1600 (510) before, so they should go close to fitting.. I reckon you're best bet is to just try
them and see,
James.
Posted on: 2001/10/18 8:57
From Good Old Knockfull, Tennessee, USA
I will assume that the Pulsar wheels will need spwcers to fit on the front of a 1200. The stock 1200 wheels are close to the struts already but the Pulsar wheels are recessed
and will hit the struts for sure. They MAY fit the rear though.
Posted on: 2001/10/18 9:20
yeah they fit. i've seen them on a 1200 ute before. so they shouldnt be too mcu
hassle to put on
Justin
Posted on: 2001/10/20 2:27
