#1 building a 1400 turbo what mods
moridat Posted on: 2014/9/3 10:51
hi im building A1400 for t25 turbo what should I do to the engine with regards to bore pistons forged or standard...cam.... balanced and any thing else looking at blow through system......thanks
moridat
#2 Re: building a 1400 turbo what mods
LittleFireyOne Posted on: 2014/9/4 1:24
The more meat in the bores the safer it is to add more boost, so depending what you can get acsess to or how much boost you plan on running that's a starting point.
Can grinders can grind up a can optimized for Turbo engines, they have I believe they have less overlap or something. Balancing an engine should be a no brainer, it helps lengthen the life of the bearings and probly the rings to some extent. If you are are after torque and drivability I may suggest to not lighten the flywheel when balancing, but its more about what you want to do with the engine
#3 Re: building a 1400 turbo what mods
Trav Posted on: 2014/9/4 4:18
Hey Moridat,
PM Big D. Not sure he is on here much anymore but he has been through a few setups to get his A14 Turbo running right and may have a few tips for you.
Cheers
Trav
