Parts on the test block
From Creswell, Oregon USA
I am making up a couple of these Master cylinder braces for testing.
Apparently our firewalls flex quite a lot when some decent leg force is applied.
Stay tuned... I will release other part images of what I have on the "To be machined" list in this thread..
Posted on: 2014/9/5 20:44
Re: Parts on the test block
Now available once more only with more metal.
Posted on: 2014/9/6 1:18
From Melbourne, Aus.
What's the cost of the vent covers?
Posted on: 2014/9/6 2:04
$250.00 = Left and Right
You will need to sand the surf milling marks off the surface if you want them totally smooth. I will do it for an additional $50
Matt D.
Posted on: 2014/9/6 3:21
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Adelaide
Are you machining the vents out of aluminium? You could get them anodised or chromed if they are.
Posted on: 2014/9/7 0:51
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Yessir, 6061 aluminum.
Posted on: 2014/9/7 3:16
Parler @MDMachine
Anodized cowl vent grilles? ......ssssexy.
Posted on: 2014/9/8 11:10
Gotta get a quantity of parts in a batch to have the anodizing be cost effective.
Wish I had the gear to plate these myself.
Posted on: 2014/9/9 2:24
Parler @MDMachine
From Sydney Australia
Not hard or expensive to put together check out this site for Home Anodizing.
http://www.bryanpryor.com/anodizing/
Posted on: 2014/11/1 22:35
Quite a regular
can you anodize metal parts this way as well
Posted on: 2014/11/2 0:23
