heater water switch
From Brisbane Aust.
My heater switch leaks when turned on. Any good ideas on a replacement. Or is it just go to the wreckers and find an old one or try and by a new one from nissan
Posted on: 2004/5/31 9:20
Re: heater water switch
From Nelson Bay (NSW)
some thing happen to my van couldnt get one so i put a ball valve in till i got one. i got mine from a boat shop
Posted on: 2004/5/31 12:25
From South Africa, Bloemfontein
Hi there
I am glad I am not the only one that has a heater switch problem.
Mine is gummed in the close position.
I am going to try Nissan for a new one.
I would reccomend you do the same.
A new one will last you longer than a wrecker one that you do not know alot about.
How are you going to replace yours?
have you seen how difficult it is going to be!!!!
I am thinking of removing the whole airbox and then replacing the switch and then putting it back in again.
It is going to be a job but its ok.
How are you going to do yours?
Good luck
Posted on: 2004/5/31 13:26
1977 Datsun 1200GX
From Brisbane Aust.
When I found it was leaking (second day I had the car) I realised it was going to be a tough job. I am not the smallest bloke around and it will be tough contorting my frame to get at the heater and switch.
They still make the Bakkie in SA so it should be easier for you to get parts I guess.
I also thought of the ball cock. I did this to my 1956 Morris 1000. However I am trying to keep this one original mechanically.
Posted on: 2004/5/31 22:13
