Re: Elrich11's CA18DET 1200 Ute
From Brisbane
I have an s13 setup in my ute. I'm using S12 LCAs but had to section about 25mm out of each one to get the track back within the requirements. I section the area between the ball joint and the castor rod mount. The engineer I'm using for the design code (Ls3) is happy with this.
Posted on: 2015/1/17 10:00
Subject Poster Date
     Elrich11's CA18DET 1200 Ute Elrich11 2014/12/15 11:03
       Re: Elrich11's CA18DET 1200 Ute Anonymous 2014/12/15 11:14
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2014/12/15 11:27
           Re: Elrich11's CA18DET 1200 Ute demacoz 2014/12/16 1:46
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2014/12/15 11:15
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/15 10:58
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/15 11:07
       Re: Elrich11's CA18DET 1200 Ute nismo1 2015/1/15 13:53
       Re: Elrich11's CA18DET 1200 Ute meandatto 2015/1/16 7:59
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2015/1/16 8:22
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/16 9:22
             Re: Elrich11's CA18DET 1200 Ute ddgonzal 2015/1/16 9:26
               Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/16 9:51
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/16 10:02
       Re: Elrich11's CA18DET 1200 Ute mrbarista 2015/1/16 10:06
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/17 9:17
         Re: Elrich11's CA18DET 1200 Ute mcdat 2015/1/17 9:29
           Re: Elrich11's CA18DET 1200 Ute Anonymous 2015/1/17 9:38
             Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/17 9:55
       Re: Elrich11's CA18DET 1200 Ute ___1200ute 2015/1/17 10:00
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/1/17 10:09
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/2/22 10:15
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/18 1:08
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/18 1:11
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/18 1:14
       Re: Elrich11's CA18DET 1200 Ute zigmondo 2015/4/19 23:41
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/20 1:09
           Re: Elrich11's CA18DET 1200 Ute zigmondo 2015/4/20 8:23
       Re: Elrich11's CA18DET 1200 Ute cadet1200 2015/4/20 6:58
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/20 11:12
       Re: Elrich11's CA18DET 1200 Ute meandatto 2015/4/20 10:23
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/20 11:19
       Re: Elrich11's CA18DET 1200 Ute bobby_sr20 2015/4/20 12:18
       Re: Elrich11's CA18DET 1200 Ute meandatto 2015/4/21 9:22
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/4/22 13:51
         Re: Elrich11's CA18DET 1200 Ute meandatto 2015/4/23 9:19
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/8/4 4:42
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/10/31 13:12
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/10/31 13:55
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/10/31 14:03
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/10/31 14:04
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2015/11/1 4:51
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/11/1 6:29
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/11/29 9:10
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2015/11/29 9:23
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/5 4:21
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/5 4:22
         Re: Elrich11's CA18DET 1200 Ute supafatto 2015/12/5 5:04
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/5 5:23
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/19 5:24
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2015/12/19 5:34
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/19 5:51
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/19 5:47
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/19 6:20
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2015/12/19 7:39
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2015/12/26 13:52
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/1/16 6:34
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/1/16 6:49
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/1/16 6:51
             Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/1/17 5:22
               Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/1/19 13:35
       Re: Elrich11's CA18DET 1200 Ute ANGE 2016/1/20 4:37
       Re: Elrich11's CA18DET 1200 Ute sikyne 2016/1/20 5:18
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/1/20 8:02
       Re: Elrich11's CA18DET 1200 Ute sikyne 2016/1/20 13:15
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/1/26 11:05
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/4 21:01
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/4 21:05
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/3/4 22:59
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/5 0:13
             Re: Elrich11's CA18DET 1200 Ute D 2016/3/5 1:41
             Re: Elrich11's CA18DET 1200 Ute COUP1200 2016/3/5 1:47
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/5 2:01
         Re: Elrich11's CA18DET 1200 Ute Anonymous 2016/3/5 3:41
           Re: Elrich11's CA18DET 1200 Ute COUP1200 2016/3/6 8:07
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/16 11:23
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/16 11:36
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/3/20 10:37
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/3/21 23:50
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/4/21 12:49
         Re: Elrich11's CA18DET 1200 Ute zigmondo 2016/4/21 22:47
           Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/4/22 8:10
             Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/4/22 9:52
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/5/22 8:22
         Re: Elrich11's CA18DET 1200 Ute supafatto 2016/5/24 9:24
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/5/24 13:17
             Re: Elrich11's CA18DET 1200 Ute supafatto 2016/5/24 14:44
               Re: Elrich11's CA18DET 1200 Ute datsa73 2016/5/24 15:40
                 Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/5/25 10:10
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/6/11 0:01
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/6/14 1:11
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/6/25 17:05
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/6/26 2:09
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/7/24 10:38
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/7/24 10:58
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/7/24 11:24
             Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/7/25 11:07
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/6 8:38
       Re: Elrich11's CA18DET 1200 Ute DatsAndy 2016/8/6 10:40
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/7 5:53
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/8/7 6:29
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/7 7:00
       Re: Elrich11's CA18DET 1200 Ute zigmondo 2016/8/7 7:16
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/26 3:09
         Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/8/26 5:08
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/8/26 5:08
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/26 6:01
             Re: Elrich11's CA18DET 1200 Ute Ninno 2016/8/26 11:52
               Re: Elrich11's CA18DET 1200 Ute ANGE 2016/8/26 13:19
                 Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/27 0:25
               Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/8/27 0:22
       Re: Elrich11's CA18DET 1200 Ute xr6blake 2016/9/27 9:46
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/9/27 10:45
           Re: Elrich11's CA18DET 1200 Ute xr6blake 2016/10/2 9:02
             Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/10/2 10:08
       Re: Elrich11's CA18DET 1200 Ute zigmondo 2016/9/28 10:34
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/9/28 11:22
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/11/27 10:57
         Re: Elrich11's CA18DET 1200 Ute trb012 2016/11/29 21:45
           Re: Elrich11's CA18DET 1200 Ute D 2016/11/30 2:43
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/11/30 9:25
       Re: Elrich11's CA18DET 1200 Ute D 2016/11/30 16:16
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/11/30 23:35
           Re: Elrich11's CA18DET 1200 Ute D 2016/12/1 6:30
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/12/20 8:41
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/12/20 8:43
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2016/12/20 11:02
           Re: Elrich11's CA18DET 1200 Ute zigmondo 2016/12/21 3:12
       Re: Elrich11's CA18DET 1200 Ute zigmondo 2016/12/21 3:15
         Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/12/21 4:44
           Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/12/21 8:08
             Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/12/21 9:36
               Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/12/21 10:25
                 Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/12/21 10:48
                   Re: Elrich11's CA18DET 1200 Ute Elrich11 2016/12/21 11:18
                     Re: Elrich11's CA18DET 1200 Ute ddgonzal 2016/12/21 22:33
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2017/3/1 9:27
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2017/3/12 8:12
         Re: Elrich11's CA18DET 1200 Ute zigmondo 2017/3/13 20:14
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2017/3/13 22:07
       Re: Elrich11's CA18DET 1200 Ute Elrich11 2018/7/20 2:05
         Re: Elrich11's CA18DET 1200 Ute cadet1200 2018/7/20 13:58
           Re: Elrich11's CA18DET 1200 Ute demacoz 2018/7/20 23:42
             Re: Elrich11's CA18DET 1200 Ute oda70 2018/7/24 10:58
               Re: Elrich11's CA18DET 1200 Ute Elrich11 2018/7/24 23:26
                 Re: Elrich11's CA18DET 1200 Ute supafatto 2018/7/25 8:59
                   Re: Elrich11's CA18DET 1200 Ute Elrich11 2018/7/25 23:24
           Re: Elrich11's CA18DET 1200 Ute Elrich11 2018/7/24 23:17
             Re: Elrich11's CA18DET 1200 Ute Elrich11 2018/7/24 23:21
       Re: Elrich11's CA18DET 1200 Ute andrep 2018/7/24 13:19
         Re: Elrich11's CA18DET 1200 Ute Anonymous 2018/7/24 13:22
