Stumpy Gear Box Owners Question
From Port Douglas. QLD
Im wondering what you have done to calibrate your speedos in your utes if your running the stumpy gearbox and stock diff.
I know wheel size will come into play etc.
Has anyone found a pinion gear that comes close or are you using a corrector box?
Just organizing one of the last few little things before mod plate inspection....one of which is a functional and accurate speedo.
Cheers
Posted on: 2015/1/23 11:41
1200 ute
ca18det
Re: Stumpy Gear Box Owners Question
Datsun 1200 uses a 17T pinion gear (when running stock diff ratio and stock diameter tires).
17T pinion is available for the FS5W71B gearboxes, along with others, about $20 at Nissan.
Posted on: 2015/1/23 11:50
Correction box. Makes It easy if you can get diff ratios or tyre sizes
Mine was $100 through speedscreen in melb
Posted on: 2015/1/23 11:56
