Cat Converters?? Do we need them
From NSW, Australia
Hi, im wondering what the laws are in NSW with regards to Cat converters on datsuns? Are all the guys with CA18,s & 4AGE engines etc running cats on there exhausts?
What about a A series with twins running premium fuel?
Posted on: 2015/2/27 9:07
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Cat Converters?? Do we need them
From Central coast NSW
The only time u don't need a cat is when it didn't come out with one like early model vehicles but if u modify it by putting a different engine in it which came out with a cat then it is required to get it past engineering and pass a emissions test as well...
Posted on: 2015/2/27 12:55
From NSW, Australia
ok so all A series motors dont need cat converters? even if its turbo or efi? only original motors that came with Cats need them fitted.
Posted on: 2015/3/2 5:26
Cheers,
Big D
NCP national code says that equivalent replacement engines only need to comply with ADRs for the car. ADR 37 didn't start until 1981? so doesn't apply to B110. Further, a replacement A12 doesn't need to comply with ADR 37 even it is a newer engine.
Performance engine swaps are different. So if upgrading to an A14, the ADR of the engine year needs to be met. If upgrading to a CA18DE and the S13 required cats, then you need cats.
Posted on: 2015/3/2 5:45
From NSW, Australia
Thanks for that, my 1200 is older that 1981 but my A14 is from a Sunny and im not sure of the age. ill have to look into it a little more.
Posted on: 2015/3/6 2:47
Cheers,
Big D
