Re: DIY alternator battery charger setup
Well if you use an LS t-connector alternator, you only need three wires
* positive to A/BAT and S
* negative to E
* 12v light between A and L
Per Basic Alternator Wiring
Don't forget a Fusible Link for safety. Won't blow like a fuse, but help prevent fires.
You can use a generic $3 link.
But you also need a small charged battery (or other 12V DC source) to initialize the charging. If the batteries to be charged aren't too run down they will be enough.
Posted on: 2015/3/22 10:34
Subject Poster Date
     DIY alternator battery charger setup reuby_tuesday 2015/3/22 9:31
       Re: DIY alternator battery charger setup ddgonzal 2015/3/22 9:49
         Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 10:19
           Re: DIY alternator battery charger setup ddgonzal 2015/3/22 10:34
           Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 11:40
             Re: DIY alternator battery charger setup ddgonzal 2015/3/22 12:18
               Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 12:37
                 Re: DIY alternator battery charger setup ddgonzal 2015/3/22 20:35
                 Re: DIY alternator battery charger setup reuby_tuesday 2015/3/29 12:29
                   Re: DIY alternator battery charger setup ddgonzal 2015/3/29 13:05
                     Re: DIY alternator battery charger setup Weekend1000 2015/3/30 13:17
       Re: DIY alternator battery charger setup reuby_tuesday 2015/3/31 4:22
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/3/31 9:49
         Re: DIY alternator battery charger setup reuby_tuesday 2015/4/7 13:56
           Re: DIY alternator battery charger setup ddgonzal 2015/4/7 20:44
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/4/8 9:57
       Re: DIY alternator battery charger setup reuby_tuesday 2015/4/8 13:46
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/4/9 9:14
         Re: DIY alternator battery charger setup Dundee1000 2015/4/9 10:46
         Re: DIY alternator battery charger setup reuby_tuesday 2015/4/9 14:58
