Re: DIY alternator battery charger setup
Looks good to me. Voltmeter will tell you how the charging system is working.
Ammeter will indicate when the battery is done taking a charge. Although after 15 minutes any battery should be done, with no danger of overcharging. The built-in regulator means a precision charge.
Should work much better than a typical 120V mains charger.
Posted on: 2015/3/22 20:35
Subject Poster Date
     DIY alternator battery charger setup reuby_tuesday 2015/3/22 9:31
       Re: DIY alternator battery charger setup ddgonzal 2015/3/22 9:49
         Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 10:19
           Re: DIY alternator battery charger setup ddgonzal 2015/3/22 10:34
           Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 11:40
             Re: DIY alternator battery charger setup ddgonzal 2015/3/22 12:18
               Re: DIY alternator battery charger setup reuby_tuesday 2015/3/22 12:37
                 Re: DIY alternator battery charger setup ddgonzal 2015/3/22 20:35
                 Re: DIY alternator battery charger setup reuby_tuesday 2015/3/29 12:29
                   Re: DIY alternator battery charger setup ddgonzal 2015/3/29 13:05
                     Re: DIY alternator battery charger setup Weekend1000 2015/3/30 13:17
       Re: DIY alternator battery charger setup reuby_tuesday 2015/3/31 4:22
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/3/31 9:49
         Re: DIY alternator battery charger setup reuby_tuesday 2015/4/7 13:56
           Re: DIY alternator battery charger setup ddgonzal 2015/4/7 20:44
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/4/8 9:57
       Re: DIY alternator battery charger setup reuby_tuesday 2015/4/8 13:46
       Re: DIY alternator battery charger setup lamb_daiquiri 2015/4/9 9:14
         Re: DIY alternator battery charger setup Dundee1000 2015/4/9 10:46
         Re: DIY alternator battery charger setup reuby_tuesday 2015/4/9 14:58
