#21 Re: 1200 Wheels - Confused!
choppedsprings Posted on: 2015/3/18 11:58
What fronts struts do have in the car? By the sound of it I would be looking for some b310 sunny wheels and do the measurements on them.
#22 Re: 1200 Wheels - Confused!
zordmaker Posted on: 2015/3/19 9:47
Struts are standard B110 with drums.
OK guys.. the decision has been made. Five 12" stock hubs now sitting outside the shed. Now to get busy with the sandblaster and paint then look for some quality rubber.
Oh yes, and if anyone has any, some original hubcaps.
Thanks for all the help.
ZM
#23 Re: 1200 Wheels - Confused!
Beautute Posted on: 2015/4/3 3:22
Hi Zordmaker, I noticed that you found a wrecker in Smithfield, I need a disc brake wheel hub ASAP. The struts and brakes I am fitting had a damaged hub, apparently where the wheel bearing must have given out so I need another hub. Could you please point me to this wrecker. PS. I live in beautiful Perth. Thanks. Matty :)
#24 Re: 1200 Wheels - Confused!
zordmaker Posted on: 2015/4/3 9:09
Your best bet is probably the Datto wrecker in Adelaide:
http://www.grandauto.com.au/
I know he ships. The Smithfield guy does not.
#25 Re: 1200 Wheels - Confused!
Beautute Posted on: 2015/4/4 2:36
Thanks mate, I will check it out. Matty
« 1 2 (3)
