60 series box gearstick pin size
From Coondle, WA Australia
I'm still stuffing around with this 60 series box and I've discovered that the gearstick pin for a 60 series is slightly smaller than everything else or at least mine is.
Put the verniers on a pin 8.9mm
A 56 4 speed hole is 9.0mm
Measure my 60 5 speed and its 8mm.
Is this normal and if so does anyone have the right pin?
Posted on: 2015/4/11 4:21
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Re: 60 series box gearstick pin size
Some use a pin with a circlip
Others use a shoulder bolt, one end being smaller diameter. So measure the 2nd hole.
Posted on: 2015/4/11 4:28
Notice the difference between the two
Posted on: 2015/4/11 5:42
