120y sedan tail shaft same length as 1200 sedan??
From Adelaide
Can i put a put a 120y sedan diff and tailshaft in a 1200 sedan i know the diff goes in but is the tail shaft the same length???
anybodys help appreciated..
Posted on: 2004/6/6 3:13
Re: 120y sedan tail shaft same length as 1200 sedan??
Unknown. But if you measure the tailshaft you have, I'll measure the 1200 tailshaft and post the measurements here.
The wheelbase of B210 is longer than B110 by 40mm.
Posted on: 2004/6/6 4:02
1200 tailshaft measurements here
From the part numbers, it seems that the B210 and B110 driveshafts are the same length. Only automatic vs manual lengths are different.
Posted on: 2004/6/6 4:40
From Melbourne, Australia
a 120y tail shaft is the same length but were the diff is it is not the same u need a 120y diff 2
Posted on: 2004/6/6 5:20
When the going gets tough the Datsun keeps going😋
