« 1 (2)
Re: Link Mikuni
From Lisbon
Hi!
Many thanks for your quicly replies.
Let me Know if i understood, because my englsh is not the best
You told me or i understand to make 4 holes on intake mainfold with 3.5mm diāmeter drill
runner means individual intake? My intake mainfold has 4 runners? Correct? So i will make four drills on top to each runner. After i put it on 4 bleeders (like you inform on E-BAY I WILLBUY IT) with hoses and lknk all 4 hoses to 1 hose and put the pcv valve and then to block breather
That`s it mr Lamb?
Thanks
Luis
this intake on picture has four marks to drill near where the carbs were be acopulated. that i will or wont to do?
I want to do a precision job, so i need every detail
jpg  iNTAKE.jpg (8.94 KB)
6267_54f84218bbac7.jpg 259X194 px
Posted on: 2015/3/5 9:12
Edited by Luigi on 2015/3/5 11:46:45
Edited by Luigi on 2015/3/5 11:48:19
Edited by Luigi on 2015/3/5 13:39:44
Edited by Luigi on 2015/3/5 21:10:07
Re: Link Mikuni
From Sydney Australia
the cast sections near the carbs are usually drilled to accomodate mounts for the throttle shaft linkages using a rod end, I would drill some small holes near the cylinder head face section and then link together with 3mm id rubber vacuum hose and take of from there whatever you need.
Using a single point for Brake vacuum is not as good as using two points of vacuum supply better feel with less pulsing at lower rpm.
Yes you manifold has four runners going each to an individual cylinder, I take it you are using a Redline Australian made twin side draught manifold or is it a Japanese one like Tomei?
Mikuni Solex side draughts mount solid with a phenolic (Bakelite like plastic) heat proofing spacer, Webers or dellorto Carburettors like a soft mount though the best of these were fitted standard to the datsun 2000 Roadster with the 150 HP engine option with twin 44mm Mikuni Solex sidedraught carburettors.
They may still be able to be found if you look here where they make good replacement parts.
http://www.fairladyparts.com/page28.html
Posted on: 2015/5/3 4:51
Re: Link Mikuni
From Adelaide
Hi Luigi, I think between what you've said and what Steve said you've got it all under control.
Posted on: 2015/5/3 21:18
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
« 1 (2)
