How to find out what engine is installed
From Sydney, Australia
Hi Guys,
I recently bought a ute. The previous owner said that he had installed a datsun 120y engine on it. The VIN plate says A12, but how to tell exactly tell what engine it has got atm? are there different versions of A12?
And does anyone know where I can buy a full engine rebuilt kit?
Thanks
Ron
jpg  VIN.JPG (92.34 KB)
18758_55502772ece51.jpg 727X563 px
Posted on: 2015/5/11 4:52
Re: How to find out what engine is installed
G'day mate and welcome to the forums,
To tell what engine you have, you need to locate the Engine ID Mark which is on the engine block itself. The number is on the left (distributor) side of the engine.
I am led to believe the 120y's came out with A12, A14 and some even A15.
There are variations of each engine.
If it is in fact an A12, there was an "early" and "late" version. The later version (1974 onwards) will have the distributor toward the middle of the block as opposed to being right up the front.
Visit Tech Wiki - Nissan A Engine for more info
and Tech Wiki - A12 Engine.
Tech Wiki - Engine ID Mark
Datsun1200.com member "bige" can help you with a full rebuild kit as can several other places including precision international.
Hope this helps.
Posted on: 2015/5/11 6:00
Thanks ruredi,
Really appreciate your comment. Will trying looking up for that number 2night. I tried sending PM to bige but didnt get any reply.
Posted on: 2015/5/11 6:04
On the registration Sticker it says engine number as A14760805. Does this means it is an A14 engine?
Posted on: 2015/5/11 6:25
If the engine has the same number as that, then yes it will be the A14 (1.4L).
Precision International - A14 Parts List
Posted on: 2015/5/11 6:32
From sydney australia
The previous owner could have removed the A14 & fitted an A12, but not change the engine number with the RTA. The only way to be sure is to check the engine number, which is on a machined area behind the distributor. If it had an A14,you'd have thought the seller would have told you.
Posted on: 2015/5/11 9:33
Thanks Guys,
Finally found the number and it is A12 :) it says A12 290167E. Anyone knows what the other numbers mean?
Posted on: 2015/5/11 10:49
From your other pic looks like a 120y type later a series as all ignition leeds end up on dizzy near cyl 3.
Posted on: 2015/5/11 11:29
120Y means A12-powered B210.
A14 powered B210 was not badged as 120Y.
See 120Y
Posted on: 2015/5/11 12:14
Hi Guys,
Attaching a picture of my engine bay, if this helps. The number engraved on the engine is A12 290167E so I am guess it is an A12 engine.
If it is Datsun 120y A12 will the piston size, rings & gaskets still be the same as normal A12?
Kind Regards,
Ron
jpg  engine2.JPG (174.00 KB)
18758_5551376d9ffe5.jpg 1267X719 px
Posted on: 2015/5/12 0:12
