« 1 (2)
Re: VG30E vs DE
Quite a regular
LOTS when you consider the intake manifold. The blocks are similar size, but the DE heads and
manifold are much bigger.
Here'a a 1600 with w VG30E
http://www.datsuns.com/510/dietzbay.jpg
Here's my 1600 with a VG30DE
http://www.datsuns.com/red/vg30de-510.jpg
The DE is also about 30lbs heavier. The tradeoff is the DE has 60 more HP.
Dave Lum
'71 1600 w/ VG30DE
www.datsuns.com
Posted on: 2001/10/27 1:46
Re: VG30E vs DE
Quite a regular
Both will fit with a bit of work as Dave has shown. I have also seen VG30DETT and VG30ET motors fitted - the VG30DETT requires some rather obscene mods to make it fit - usually a combination
of firewall, chassis rail mods and custom turbo manifolds (eg turbos pointing up rather than down etc), steering mods etc...
I'd suggest E over DE due to the ease of the job and the difference in price, especially if turboing is on the agenda. there is also a DET engine.
Claimed kw from the factory for all the turbo engines:
VG30ET - 146kw, VG30DET - 190kw, VG30DETT - 209 kw (japanese maximum horsepower limit - probably more like 220kw in reality).
Note that the electronic fuel injection and turbo on the older VG30 E engine are crude by comparison to the later ones and these are easy spots to find some of the missing horsepower.
Although there's a price to be paid in $$$, it still may work out easier and cheaper to get similar performance - don't forget the weight differential too - especially between an ET and a
DETT.....
As another alternative there is a VG20 series engine as well, unfotunately this is almost impossible to find in rwd format and uses the same gearbox as the 300ZX's (I think the RWD one is
from Japanese 200ZX fairlady and the FWD one is from Maxima's). Whoops, shouldn't have mentioned that as it may start to push the price of these up - they've been a bit of a secret and can
be had very cheaply. So shhh! - don't tell anyone.
As you can see I've done a bit of research into engine swaps for my 1200 ute...
Posted on: 2001/10/27 9:52
Re: VG30E vs DE
hi my name is brent
Posted on: 2001/10/28 4:15
Re: VG30E vs DE
hi my name is brent
and as you seem to know a bit about engine transplants i was wondering if you could give me any indepth info on placing a CA18 double overhead cam engine in my datsun 1200 ute
75 model if so please Email me at Datto23@hotmail.com
thank brent
Posted on: 2001/10/28 4:19
Re: VG30E vs DE
From UK
I've seen a VG20ET in a Y31 Nissan Cedric before and they are RWD. Some Japanese spec Y30 Cedrics or Glorias (probably sold as a Nissan 300C in Oz like it was here) also have a
VG20 in RWD layout although normally aspirated.
Eddie Rattley
(England)
www.ratdat.com
Posted on: 2001/10/28 4:49
Re: VG30E vs DE
Quite a regular
Depends on the country you're in, the version of the CA18 DE (T?) you're after, etc. Personally (although it's a common swap these days and a far better one than a SR20 for a lot of reasons)
it wouldn't be my favorite choice for the ute. As a starting point you will not be able to run a brake booster without some very interesting engineering (can be done but not easily due to the
width of the head and intake manifold) which may be required from an engineering perspective (brakes versus engine/speed potential and all that). Depending where you are a larger master
cylinder and front strut swap may be enough, although it may not be. Just doing this will greatly increase pedal pressure (good if you like having one leg much bigger than the other). It is
legal in most places in Australia, where pre 1977 cars can get away with a lot more radical swaps....
Any gearbox which fits to the CA18 and has enough strength to survive a bit of use means cutting out and replacing the tranny tunnel from something bigger - this generally requires changes to
your heater setup (usually to B210/1600 heater arrangement).
Most engineers would also require a diff swap to stand up to the extra power of the CA18 - even the non turbo version has twice the power of the A12....
Some places require chassis strengthening as well. (Seam welding or bracing).
Few aftermarket fuel injection computers can communicate with the Nissan crank angle sensor(and multi coils), so your options here are limited , increasing costs , or you need to find a good
original one and some way of translating the wiring diagram (good if you're an electrician and it's not in japanese) (and hopefully ensuring all the bits like airflow sensors, oxygen sensors
etc are there.
Most mid 80's on Japanese autos require very specific feeds from their computer and are virtually impossible to use any aftermarket computer.
You will probably need to either change fuel tank to a fuel injected one of a similar size or run a seperate surge tank and twin high pressure fuel pumps. Entire fuel lines will need to be
changed due to the much higher pressure and flow required for injection.
This is just for starters. Think also gearshift lever location, tailshaft length, speedo/tacho connections, radiator changes, engine mount swaps/modifications, crossmember swaps, power
steering/ Air conditioning pumps, etc...
Other suitable options A14/A15 (carb or fuel injected) - easiest possible swap, Ca20/Ca20e (carb or elec ign/fuel inj versions) like above but single cam and very compact - not renowned for
reliability tho , Z18/Z20/Z22/Z24 (plus turbo versions eg Z18T - fuel injected but can be connected up using fuel only efi computer and electonic dizzy), KA20/KA24 (similar to Z but twin
cam E15/E15T (FWD only but can be fitted with gearbox bellhousing mods) (carb/elec ign or fuel inj turbo). That's just a start of the Nissan ones. Toyota and Mazda (Rotary turbo - Woohoo!)
engines can also fit easily, and even V8's can fit, Buick/GM/Holden V6's etc....
Start with a hot carb/cam exhaust A15 and think about the others while you save your bucks for the job, and the insurance)..... And start checking out some of the guys websites who have how-
to photos.....
Posted on: 2001/11/1 3:26
Re: VG30E vs DE
Quite a regular
We only got the 3 litre as far as I know - otherwise it would have been a 200. And yeah, it was a 300C. It never sold well here. Too heavy, too butt ugly, and that end of the market
is dominated by Aussie built Holden Commodores (GM(Buick)/Opel/Vauxhall based but bigger) and Ford Falcons (like a Cortina/Granada but bigger).
Very rare to get bits for and too expensive unfortunately. Dunno what a Y31 Cedric is although I highly suspect it's like our R31 Pintara..... (like an R31 Skyline but cheaper and
nastier)
Posted on: 2001/11/1 3:32
« 1 (2)
