Re: Cheap Stainless steel extractors on ebay
From Gold Coast,QLD.
Well they turned up quick,nice surprise to get home from work to!
I first grabbed a magnet and it didn't stick to the pipes which means quality is not as cheap as i thought they would be,as to the many sheets of 1.2mm 304 no.4 s/s that i have used from china and a fridge magnet would stick to them without hesitation!
Will have to give them time to see if they crack or not.
To my surprise they do fit a GX twin weber manifold,where i thought it might touch on number 4 primary it has a good 3-5mm clearance but number 1 only has 2-3mm clearance between them which is cutting it a bit fine for heat transfer to inlet manifold.
I measured tube thickness on primary,36mm/1.5mm wall so they are 33mm id and outlet is 50.8mm/1.5mm wall so 47.8mm id!
All bends are machine mandrel not press bent.
Overall they look pretty good for the money so time will be the test to see how they last!
Posted on: 2015/6/17 6:28
Edited by MYB110 on 2015/6/17 7:02:24
SLICK & SMALL IS THE WAY TO HAUL!!!!
Subject Poster Date
     Cheap Stainless steel extractors on ebay MYB110 2015/6/14 3:05
       Re: Cheap Stainless steel extractors on ebay sikyne 2015/6/14 3:41
         Re: Cheap Stainless steel extractors on ebay DA70YO 2015/6/15 12:22
           Re: Cheap Stainless steel extractors on ebay Turboute 2015/6/15 12:29
             Re: Cheap Stainless steel extractors on ebay ddgonzal 2015/6/15 21:37
             Re: Cheap Stainless steel extractors on ebay Turboute 2015/6/15 23:36
       Re: Cheap Stainless steel extractors on ebay lamb_daiquiri 2015/6/14 5:15
         Re: Cheap Stainless steel extractors on ebay elemental_funk 2015/6/14 10:54
           Re: Cheap Stainless steel extractors on ebay dix1000 2015/6/15 2:08
             Re: Cheap Stainless steel extractors on ebay D 2015/6/15 4:41
       Re: Cheap Stainless steel extractors on ebay MYB110 2015/6/15 21:48
         Re: Cheap Stainless steel extractors on ebay ddgonzal 2015/6/15 22:09
       Re: Cheap Stainless steel extractors on ebay clyons8 2015/6/16 1:11
         Re: Cheap Stainless steel extractors on ebay ddgonzal 2015/6/16 4:08
           Re: Cheap Stainless steel extractors on ebay D 2015/6/16 15:44
       Re: Cheap Stainless steel extractors on ebay MYB110 2015/6/17 6:28
         Re: Cheap Stainless steel extractors on ebay benny 2015/6/17 6:52
           Re: Cheap Stainless steel extractors on ebay Turboute 2015/6/17 7:03
       Re: Cheap Stainless steel extractors on ebay MYB110 2015/6/17 7:27
       Re: Cheap Stainless steel extractors on ebay lamb_daiquiri 2015/6/17 9:19
       Re: Cheap Stainless steel extractors on ebay MatthewSturdee 2015/6/18 0:36
       Re: Cheap Stainless steel extractors on ebay DA70YO 2015/6/18 0:47
       Re: Cheap Stainless steel extractors on ebay MatthewSturdee 2015/6/21 11:38
         Re: Cheap Stainless steel extractors on ebay benny 2015/6/21 11:52
           Re: E85 or 98 ddgonzal 2015/6/21 22:09
           Re: Cheap Stainless steel extractors on ebay MatthewSturdee 2015/6/21 22:40
             Re: Cheap Stainless steel extractors on ebay D 2015/6/21 23:12
       Re: Cheap Stainless steel extractors on ebay Turboute 2015/6/22 2:53
         Re: Cheap Stainless steel extractors on ebay Mattndew76 2015/6/22 3:38
           Re: Cheap Stainless steel extractors on ebay benny 2015/6/22 12:38
       Re: Cheap Stainless steel extractors on ebay MYB110 2015/6/22 7:10
       Re: Cheap Stainless steel extractors on ebay D 2015/6/22 15:08
         Re: Cheap Stainless steel extractors on ebay Mattndew76 2015/6/22 17:14
       Re: Cheap Stainless steel extractors on ebay D 2015/6/23 4:22
         Re: Cheap Stainless steel extractors on ebay Mattndew76 2015/6/23 6:40
           Re: Cheap Stainless steel extractors on ebay D 2015/6/23 7:46
             Re: Cheap Stainless steel extractors on ebay Mattndew76 2015/6/23 14:28
               Re: Cheap Stainless steel extractors on ebay D 2015/6/25 4:21
                 Re: Cheap Stainless steel extractors on ebay Mattndew76 2015/6/25 6:09
       Re: Cheap Stainless steel extractors on ebay tboe0 2016/2/29 18:34
       Re: Cheap Stainless steel extractors on ebay dattoboy_nz 2016/3/1 0:58
