#11 Re: vacuum/mecanical advance
A14force Posted on: 2004/6/7 21:51
I might try sucking out the pumpgas., and trying some avgas. YEAH,YEAH, I know ten grand fine for using it on the street. Or maybe I'll try some octane booster.
#12 Re: vacuum/mecanical advance
kb110 Posted on: 2004/6/7 22:28
Hi ddgonzal
How come the factory motorsport distributors for A series Datsuns and A series British Leyland cars have no vacuum advance at all??
Ye olde Cooper S road cars bought from the local dealer had such a set up - hence I assumed it was always somewhat uneccesary for go fast applications.
#13 Re: vacuum/mecanical advance
Ash Posted on: 2004/6/7 23:06
You do have water injection don't you?
#14 Re: vacuum/mecanical advance
ddgonzal Posted on: 2004/6/8 2:19
Because they were driven WOT.
My car currently doesn't have a vacuum advance, waiting for it to be repaired. It drives fairly well. You don't need one. But if you want best street performance, use one.
#15 Re: vacuum/mecanical advance
A14force Posted on: 2004/6/8 3:30
Not yet. Probably a good idea though. I was thinking of using an old window washer bottle and pumo, with a garden irrigation nozzle to atomize the water a bit. Something else I have thought of trying, (after I get it working) is substituting the water for model areoplane "glow" fuel. Which is just nitromethane , methenol and light two stroke oil.
I had hoped to get it running a bit more happily, before starting to try other things such as that.
#16 Re: vacuum/mecanical advance
Ash Posted on: 2004/6/9 5:57
reason I suggested it is that it's a knock suppressant, so it may negate the need for a regraph. Otherwise if you change it you may need to advance the timing again once the WI is up & going.
« 1 (2)
