Browsing this Thread:   3 Anonymous Users
(1) 2 3 »
Bike Carbies
From Brisbane Qld
I would like to know What is better bike carbies to put on A14 I have big cam and
I think it would go well with the four carbs What are the best?
Posted on: 2015/10/1 8:44
Re: Bike Carbies
Some 36 or 38 mm bike carbs will be fine.
If you are using cv ones the large cam can play around with the starting like sus. They need vacuum and manifold pressure
Posted on: 2015/10/2 0:11
Re: Bike Carbies
From Brisbane Qld
So what Bands are 36 And 38ml ?
MMM I meant Brands David
Posted on: 2015/10/2 1:31
Edited by davem69 on 2015/10/2 9:37:01
Re: Bike Carbies
http://en.wikipedia.org/wiki/38_Special_(band)
36 mm is the throttle size (Stock A14T throttles are 38 mm). See our tech article Bike Carbs. Mikuni 34s seem to be ideal for round 100 hp.
* 1980- Suzuki GS1000
* 1981 Kawasaki KZ1000
* 1989-1984 SX650
Mikuni BS are CV carbies, for maximum power. What are the specs of your camshaft?
Posted on: 2015/10/2 2:37
Re: Bike Carbies
From Mordialloc Victoria 3195
I did a small project thread ( 'just finishing by bike carbs' ) with a few people wading in on pros and cons
Might help you decide
dp
Posted on: 2015/10/2 8:26
keep it simple
Re: Bike Carbies
From Brisbane Qld
Yeah Ok Thanks Guys I think 1st I save Up $$$ and keep doing the research
Posted on: 2015/10/2 20:55
Re: Bike Carbies
Be careful with a lot of the Internet research. It's half truths.
My list of what's vital is:
Mount carbies at same or close to angle as the were on bike. Side mount or down Draught
Get a wide band o2 Guage for tuning
Get the carb factory manual and clean them and learn which jet is which.
Then it's similar to tuning a carb but you have to do it 4 times.
Posted on: 2015/10/2 23:08
Re: Bike Carbies
From Las Vegas USA
Do a google search on factorypro flat slide carbs; this is specific to FCR flat slide carbs but it will give you a good idea of how bike carbs work.
I have been running the FCR carbs on my coupe for several years now and am very happy with them. I feel they offer an advantage over the traditional weber DCOEs, especially,on a track only car like mine.
Tom
Posted on: 2015/10/3 3:21
Re: Bike Carbies
From Taupo New Zealand
What advantage do you feel they offer rallytwit?
Posted on: 2015/10/6 9:28
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
Re: Bike Carbies
1. Flat-slide carburetors do not need a venturi restriction, as do CV (including SU-style) carbies, so they can make more HP similar to racing fuel injection setups.
2. Because they are not dependent on vacuum they can idle much better with high-duration (high RPM) camshafts.
That being said, bike carbs with venturis make some big HP too (32mm BS32 makes a lot more power than 38mm SUs).
Matsuoka/Mikuni MSR use the same sliding throttle valve design as Kiehin FCR but are about $1000 US cheaper. But when buying used bike carbs price is not such a big difference. If you're buying new the MSRs may be the way to go.
Posted on: 2015/10/6 9:53
(1) 2 3 »
