Re: brake issues
Yes, the pedal should be "hard", instead of soft/mushy. However it should not require unusual pedal effort (leg muscle) to slow the car. That said the brakes of a 1976 car are not up to modern standards, and the Datsun brakes are not able to lock up wide tires on dry pavement.
The booster is good if it:
* boosts the pedal effort
* doesn't leak (causing uneven engine idling)
* doesn't "grab" the brakes violently
Never heard of a booster causing 'click' sounds. I'd look at the brake pad movement (including wheel bearing adjustment and caliper sliding surfaces).
the car doesnt stop as fast as i'd like it to.
The most popular upgrade is to S13 Silvia 250 mm brake rotors. See S13 Brakes.
Posted on: 2015/11/8 20:40
Subject Poster Date
     brake issues patawic 2015/11/8 10:58
       Re: brake issues ddgonzal 2015/11/8 20:40
       Re: brake issues patawic 2015/11/9 5:22
       Re: brake issues b310gx 2015/11/10 8:41
