Re: 120y strut disc upgrade... anything else needed?
The hub fits through the center hole in the wheel. The diameter is called hub registration?
Datsun 1200 is 71 mm.
Measure this:
Posted on: 2015/11/11 1:33
The coupes were all built in Japan, so originally they came with the Japan calipers (small 1200-style). Only (some) Aussie sedans were locally built and so used locally-sourced brakes.
I suspect both used the same rotor and strut, and that only the caliper differed ... ?
Posted on: 2015/11/11 1:45
Quite a regular
good stuff, thanks for the reply ddgonzal!
my hub registration is approximately 51mm (steel rule, in the dark, by eye )
so significantly smaller than a 1200 one.
should i be looking for different calipers as a result??
Posted on: 2015/11/12 23:31
51 mm sounds like a non-Datsun hub. Who knows what it is.
Posted on: 2015/11/13 1:15
Quite a regular
feck.
will see if the strut top fits up and take it from there
Posted on: 2015/11/16 10:49
« 1 (2)
