Strange Noise on Steering wheel on turn
From Sri Lanka
Hi Guys
i have Grr rr...r noise on my b210 steering wheel when turning what would be the issue ?
thanks
regards
sumith
Posted on: 2015/12/5 6:46
Re: Strange Noise on Steering wheel on turn
Is it a squeaking sound?
Posted on: 2015/12/5 7:32
From Sri Lanka
Hi DD
Nope, it is like something is touching it while turning like Grrr....rrrr...r very low sound
,but it was not there earlier,yesterday only it started,
thanks
regards
sumith
Posted on: 2015/12/5 7:41
Hmmm
I would jack up the left wheel, and then spin it by hand.
Then jack the right wheel and spin it. If one is not as smooth as the other, suspect the bearings.
Posted on: 2015/12/5 8:03
From Sydney, Australia
Hi,
When you say noise, you mean in around the steering wheel and column?
Or the front wheels?
From your first post, I'm thinking perhaps the noise is coming from turn signal switch mechanism, the spring contact that rubs on the back of steering wheel brass ring.
This is the piece that makes the horn circuit complete to the button.
Worth a look there maybe???
Posted on: 2015/12/5 10:38
From Sri Lanka
Hi Guys
Problem Got solved eventually without any reason
no worries
thanks
regards
sumith
Posted on: 2015/12/9 10:46
Glad to hear it.
Possibly a branch got stuck in the steering linkage, then later fell off the car.
Posted on: 2015/12/9 10:58
From Townsville, Qld
My column squeaks if that helps, you know a fix for that right DD?
Posted on: 2015/12/10 23:38
I know the squeak, mine squeaked for years. Never did figure out how to get rid of the squeak!
Posted on: 2015/12/11 2:54
