A14 replacement sleave needed
Not too shy to talk
hi im new to this site i have a Morris Minot=r car that i want to install a Datsun engine into i just brought a A14 engine in parts it has had a lot of money spent on it new re bore to 0.5 mm and new rods pistons rings balancing etc over $800 at a engineering shop but after 5000 miles one piston had a small part of it break away and score the barrel i believe i could replace the sleeve, and bore it to 0.5mm over to match the rest and simply buy another piston and rings rather than do another set of re bore to 1.0mm over and a set of new piston does anyone know where i can buy a sleeve please
Posted on: 2015/12/23 13:39
Re: A14 replacement sleave needed
From St. Louis, MO USA
I have (4) new LA-31 Sleeves on the shelf. I would sell you one. 3" ID x 1/8" wall. [76mm x 3.175mm thick]
Peter in US
Posted on: 2015/12/23 19:22
Not too shy to talk
ok great i know nothing about the A14 Engine like i say i Brought one to rebuild and install in My Morris Minor it has had a re bore to 0.5mm ( approx 20 thou over ) i believe its bore std is 76mm and a stroke of 77mm , but one bore is shot i figured it would be cheaper to 1 ) buy a sleeve 2) remove the old one and install this one 3) re bore it to match the others that only have 5 k miles on them since they were re bored with new pistons and rings 4) buy a 0.5 mm over piston and rings to reinstall im not sure how much that will all cost ?
as a alternative i can buy a complete engine rebuild kit on a 40 thou over ( 1.0mm oversize ) for $186.0 See site ( http://www.rpmmachine.com/shop/index.php?l=product_detail&p=5216 )
and have the 4 barrels re bored to 1.0mm and use it to do the job What is the price of your sleeve im hoping it would fit as im hopeful there the same for the years they were built
Posted on: 2015/12/25 20:33
Nissan 11012-H7200 A14/A15 Sleeve Oversize 4.00 mm
About $17
Posted on: 2015/12/26 0:07
Not too shy to talk
ok great il take it i see your in Hawaii , im in Ca zip 92399 how much would it cost for shipping and do you take paypal? thank you
Posted on: 2015/12/26 16:06
Not too shy to talk
the next thing i will need is a 0.5mm piston and rings you dont have one of those as well do you? thanks again
Posted on: 2015/12/26 16:08
Not too shy to talk
ok great how much with shipping to 92399 thanks alwyn
Posted on: 2015/12/26 21:56
$17 is the price for a new sleeve. Click the link for a list of sellers. I don't have any.
Posted on: 2015/12/26 23:40
Not too shy to talk
how much for the sleeve to zip 92399 thanks
Posted on: 2015/12/27 16:06
Posted on: 2015/12/27 18:33
