Hazards not working
Quite a regular
From Aberdeen, UK
Hi guys,
So my Hazards aren't working, iv had a look at the wiring and there is the connector(this is connected) and then to other green wires, 1 male, 1 female spade connector, these are not connected to anything?!? what are these ment to be connected 2?
Posted on: 2015/12/29 16:45
Re: Hazards not working
Quite a regular
From Aberdeen, UK
Posted on: 2015/12/29 16:51
Those wires might go to the hazard flasher unit.
http://datsun1200.com/modules/mediawi ... dex.php?title=Lamp_Wiring
Posted on: 2015/12/29 16:55
Quite a regular
From Aberdeen, UK
i thought so to but there seems to be wires going into it already...
Posted on: 2015/12/29 17:14
Make sure that is not the turn signal flasher. The hazard flasher is a separate unit for certain models. What year and body style is your car?
Posted on: 2015/12/29 17:20
Quite a regular
From Aberdeen, UK
had a look for 2 different units. i can only see one on the right side of the column. Its a 1988 b122(japanese pickup import)
Posted on: 2015/12/29 17:30
All JDM 1200s only use only a single flasher unit.
my Hazards aren't working ...
Iv got the same switch as this
The switch was used 8608-8910 (mid-B122). Early B122 & Late B122 used different switches.
To troubleshoot:
* Do your turn signals work?
* Do all the T/S lights flash (front, rear and side)?
* When you put the Hazard switch to flash position, does the light come on and stay on (stuck) or do not light at all?
Posted on: 2015/12/29 21:02
Quite a regular
From Aberdeen, UK
So t/s work fine. All lights are working. When i flick the hazard switch i get zip, nadda. silly thing. Are the 2 green wires with spade connectors(the 2 at the bottom of the pic) supposed to be connected to anything?
Posted on: 2015/12/29 21:10
ja the two single wires of the switch... Unplug one side of the Flasher unit and plug the two wires into it. Because the switch is optional, it just plugs in
Posted on: 2015/12/29 21:44
Actually leave it connected at the flasher can, but trace the flasher can wire up to the Red connector, pull it apart there and connect the Hazard switch between Red & Green wire connectors
Posted on: 2015/12/29 21:54
