help with building a LZ20BET
From Adelaide, Australia
Hey guys back again :p. Just building up a L series motor. The bottom end I've got is a L20b bored 1mm running Mercedes forged pistons (gives me 8:1 compression). The head I'm using is a stock z18et head with stock efi manifold and turbo manifold. My questions are, whats a good non ceramic turbo that will fit on the t3 flange, what injectors will be bigger that will fit, what boost pressure can I run and will it rev over 7000 rpm cause I heard if I go over that I should use ARP conrod bolts. I'll probably run a cas and megasquirt.
Posted on: 2016/1/3 16:53
Subject Poster Date
     help with building a LZ20BET Matto1kUte 2016/1/3 16:53
       Re: help with building a LZ20BET ddgonzal 2016/1/3 22:19
         Re: help with building a LZ20BET Matto1kUte 2016/1/4 3:55
           Re: help with building a LZ20BET ddgonzal 2016/1/4 5:00
       Re: help with building a LZ20BET coxsteve 2016/1/6 11:48
       Re: help with building a LZ20BET D 2016/1/8 2:32
