#11 Re: any Americans that can supply and post 620 L series engine brackets?
ddgonzal Posted on: 2016/1/8 8:12
If you are putting in an L block, then you need a L gearbox. Short ones come from 510. Z-engine gearbox will bolt up but have a 22 degree different tilt.
The clutch is interesting on L-series.
* use the L20B clutch, as there are three sizes and it depends on the flywheel. L20B has the largest size
* the release bearing Sleeve length needed depends on the clutch cover (pressure plate)
#12 Re: any Americans that can supply and post 620 L series engine brackets?
Matto1kUte Posted on: 2016/1/8 9:09
Even though I'm using a z head? I thought I'd have to swap the engine brackets around to straighten the block as I'm using the z head thus having to use a z gearbox or am I wrong :/
#13 Re: any Americans that can supply and post 620 L series engine brackets?
ddgonzal Posted on: 2016/1/8 9:41
I think you are right. So the L engine brackets will be the wrong type?
Short Z gearbox comes from some 720 (other 720 have mid-length or long gearbox). You want a box same length as your gearbox now, which is probably a stumpy
#14 Re: any Americans that can supply and post 620 L series engine brackets?
Matto1kUte Posted on: 2016/1/8 9:53
I think all I have to do is swap them around. That's what they used to do for putting in a z18 in a s1 L series 910 here
#15 Re: any Americans that can supply and post 620 L series engine brackets?
620racer Posted on: 2016/1/8 23:36
Use a Z bellhousing with whatever gearbox you decide on. Stumpy box in Oz from 1600/510, Stanza or R30 Skyline. If your not in a hurry for the gearbox I have one in storage with a clutch and flywheel. i can bring it back to Adelaide next time I go bush.
#16 Re: any Americans that can supply and post 620 L series engine brackets?
Matto1kUte Posted on: 2016/1/9 11:54
U will have to let me know. See if I've got the $. Always spending my money on cars :p
#17 Re: any Americans that can supply and post 620 L series engine brackets?
SaCoupe73 Posted on: 2016/1/11 6:27
MADDAT in the Adelaide hills are the Datto Experts.
They can make you engine mounts to suit what ever you require.
And you would be supporting a local Adelaide business.
Cheers
Geoff
« 1 (2)
