datsun 1200 ute wheel fitment.
From Leeton NSW
Hey guys have been given the opportunity to purchase some old school jap wheels the fronts are 13x7 -1 and rears 13x7.5 -7 what are the chances of these fitting rear will fit front will be poking im thinking? Im on stock brakes and 2 inch blocks in the rear?
Posted on: 2016/1/19 5:22
Get in, sit down, shut up and hang on!!!
Re: datsun 1200 ute wheel fitment.
From Port Douglas. QLD
willtheyfit.com
this will tell you exactly how they will sit in comparison to your current wheels,
Then just do the measuring. Saved a couple of times lately
Posted on: 2016/1/19 5:27
1200 ute
ca18det
From Mordialloc Victoria 3195
You might get away with it at the front with pulled tyres , lots O negative camber and rolled lips but no chance at the rear with that offset.
once again MIGHT !!! check with techwiki
Posted on: 2016/1/19 6:33
keep it simple
Yes they will poke outside the body
But if you put small enough tires it'll work. 185/50R13 is smaller diameter than stock 155/80R12
They will fit.com
Just don't try lowering the car ...
Techwiki says:
estimate Front 185/60R13 -- requires +15 to +25 rim
estimate Rear requires 21 offset or more
Wonder how accurate those estimates are
I had ~30 mm flares with 8" +0 rims and 195 tires and there was room left over on the inside. So I suspect 205 on 7.5" -7 would work
The front is much tighter as you can't move the tire in all the way to the spring. Well you can but risk larger tires rubbing the inner bodywork while making turns. I had 175 tires on 7" +0 rims with ~20 mm flares, with no rubbing, even cleared during u-turns. But that's a relatively skinny tire
Posted on: 2016/1/19 7:05
From South East Brisbane
I'm running 14x7j 0 on the rear on standard diff, sits just outside the wheel arch. Nothing a quick guard roll couldn't fix.
Posted on: 2016/1/19 8:02
datsunikon (fb) | datsunikon (blog)
The rim doesn't come anywhere near the guard ... so what tyre are you running on that rim?
If you stretch a tyre less than 7" wide onto that rim (say a 175 tyre), it might fit inside
Posted on: 2016/1/19 8:15
