Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Alternator i brought from auto8 need wiring switched
datsunny79
Posted on: 2016/1/27 7:48
I have a 79 b310 sunny and i origanally had a hitachi alternator on and it has F N t terminal plug and A & E the new alternator has + thats a push in plug terminal.. D+ spade terminal B+ (that will be power from battery) & D- (that be earth) so i have B+ D- sorted its the D+ & + with a plug in terminal thats got me stuck?
I have been on google found a fourm on this site about changing wiring unplugging external regulator and doing a loop in the wiring? Before i cut my wiring up id like to get a 2nd opinion of what wires to do.. im guessing 1200s may be diffrent to sunnys?
#2
Re: Alternator i brought from auto8 need wiring switched
Posted on: 2016/1/27 8:44
#3
Posted on: 2016/1/27 10:17
To wire this up:
* Unplug the existing voltage regulator * The dash lamp is WR wire in the regulator harness, connect this lamp wire to D+ terminal of alternator
#4
datsunny79
Posted on: 2016/1/28 4:24
This is my original wiring.. the T terminal one was ignition power and other the feild terminal?
Thick white is 12v from battery Thick black is earth My new alternator doesnt have the T connection so where does the feild wire go? Sorry im having trouble uploading a pic of the back of my alternator
#5
Posted on: 2016/1/28 5:48
The T-wiring will not be used on the Bosch alternator. It doesn't use those wires. There is no Field wire, because the field wire comes from the Regulator and the Bosch is internally regulated. The other T-wire for the FN type alternator is the Neutral Point. This also is for the regulator. So neither of those wires are used with internally-regulated alternators
#6
Posted on: 2016/1/28 5:59
So you can run a new wire from the Lamp wire in the harness over to the D+ terminal of the alternator
Or, you re-use one of the no-longer-used harness wires, for example the Y wire. cut off the Tee-connector and put a spade connector on the Y wire, then at the regulator end of the harness, connect the Y wire to the Lamp wire You might want to double-check that D+ is supposed to be connected to the Dash Lamp
#7
datsunny79
Posted on: 2016/1/29 5:15
Sweet got it sorted thanks
Can delete this post if want to
#8
Posted on: 2016/1/29 7:20
Glad to hear it. Did it work just connecting D+ to the dash lamp or was something more needed?
