« 1 (2) 3 4 »
Re: Ga head flow compared to A series
a sentra got over 340hp with boost
Posted on: 2016/1/27 7:42
From Bridgetown, Barbados. W.I
Project 200sx at 252hp was turbocharged?
Posted on: 2016/1/27 18:50
Life's better SIDEWAYS!!
heres a dyno chart on excel for the stock to bolt on mods differences
http://web.archive.org/web/2005030520 ... ech/garage/ga16-total.xls
http://www.sentra.net/tech/garage/engine.php
heres the whole article
http://web.archive.org/web/2005030520 ... et/tech/garage/engine.php
theres around 25hp in that alone before proper port work
Port work is where you can free up the congested ports on
these heads and plenty of casted meat there from what Ive
seen in the past when sentra.net was a popular site.
Posted on: 2016/1/29 1:07
Does the ga flow more than A series?
Yes, it sure does. Mostly because it has twice as many valves in the same-size head (GA16 head bolts to the A-series block, although the oil ports don't line up exactly)
A15 -> E15 -> GA16, so it's two generations newer
Yes, using the famous Sentra disco potato
Posted on: 2016/1/29 3:34
A GA block bolts to an A-series transmission, rather than the L-series version of the 60/63?
Also, a GA could in theory be bolted into an A-series block? Presumably you'd have to use an extension of the existing A-series cam to run a timing belt up to the GA cams?
Posted on: 2016/2/1 5:54
Yes, there are two ways to use an GA engine in rear-wheel drive
* Use the Nissan GA RWD transmission (71C 5-speed)
or
* Use an A-series transmission, 3 of the main bolt holes line up, another works if drilled out a bit, the last needs some work (or just skip it)
Dunno how to get the head working on an A-series block. Those who have done it aren't saying how
Posted on: 2016/2/1 6:14
I just went and read the tech wiki about the GA series. Interesting. Now I want one.
Posted on: 2016/2/1 6:26
Engine I'm planning to use, is later non vvt engine with straight intake ports. Just need more power than A15 can deliver under 1.6cc.
Posted on: 2016/7/24 19:58
"Peter Zekert is using a whole ga16de setup in their next race car 1200 and says its almost as light as an A15".
.any info or pics of this setup??
Posted on: 2016/9/20 16:17
Posted on: 2016/9/20 17:28
« 1 (2) 3 4 »
