Fuel Guage is out of order
From Sri Lanka
Hi Guys
I got my fuel Gauge out of order , Temp Gauge is working but fuel gauge is dead checked the sensor it is working, pulled the wire from sender and grounded gauge doesn't move at all
connections and wiring are good, What would be the reason ?
is it bad gauge ?
thanks
regards
sumith
Posted on: 2016/2/13 6:37
Re: Fuel Guage is out of order
A non-working Fuel gauge is usually one of three things:
* Bad 'sender' (sensor) which is in the fuel tank
* Bad gauge in the dash
* Bad wiring
The good news is that you've already tested without the Sender, by gounding the tank wire. It demonstrates that the Sender is not the problem.
The other good news is that the Instrument Panel Voltage Regulator is working (because the Temp Gauge works)
So it's either the Gauge or the Wiring, all the wires in question are Yellow for both B110 and B210
Posted on: 2016/2/13 8:23
I would find the Body Harness to Dash Harness connector, pull it apart and test the yellow wire
1. Find dash harness Yellow wire in Dash/Body connector
2. Ground/earth this wire
3. turn IGN switch on and observe gauge:
* Gauge still dead. Check for loose wiring, at back of dash, or at dash wiring harness connectors
* Gauge works, indicates bad connection or damaged body harness wire
Posted on: 2016/2/13 8:33
From Sri Lanka
Hi Guys
I checked it in every possible way , no good i think my gauge has gone bad, is there any aftermarket product which is compatible with b210 ? please give me an idea
thanks
regards
sumith
Posted on: 2016/2/15 6:53
Most older Datsun fuel gauge are compatible, maybe even some older Nissan
* Empty mark: 73-88 ohms input
* Full mark: 12 ohms
For aftermarket, see Fuel Gauges 73-ohm
Posted on: 2016/2/15 8:13
From Sri Lanka
Hi DD
I have round Dash Gauge Set , the if i need to replace the whole dash is it compatible with my b210 structure,(Can i put squre dashboard mn my b210 ?)
i have this dash http://datsun1200.com/modules/myalbum/photo.php?lid=3656
but almost every datsun b210 here has this type
https://www.google.lk/imgres?imgurl=ht ... hVSkY4KHTqcC5AQMwhLKCUwJQ
thanks
regards
sumith
Posted on: 2016/2/15 9:14
Yes, you can bolt square dash in place of round dash
Posted on: 2016/2/15 10:11
From Sri Lanka
Hi Guys
Went through Old part stores , Could Not find good condition b210 Dash Cluster , Found b10 or b110 round cluster in good condition but don't know whether it is interchangeable with my dash bolt ? ,
it is like this nipples out the glass
will that be suitable for mine ?
thanks
regards
sumith
jpg  Dash.jpg (18.55 KB)
10994_56c2d05844b18.jpg 400X300 px
Posted on: 2016/2/16 7:32
That is a B110 instrument panel (1972 version)
If the only problem is the fuel gauge, just buy a $40 aftermarket gauge?
Posted on: 2016/2/16 7:49
From Sri Lanka
Hi DD
Yepe i was just thinking Went to hunt for one they have universal type ,they have 15 U$$ upwards, they don't specify exact Ohm Range on them will they work ?
on the manual it has 3 ranges written on it
0-90
100-180
180-280
something like this the guage doesn't specify exactly which ranage it is working,
thanks
regards
sumith
Posted on: 2016/2/16 8:06
