120y front wheel bearings
From Sydney
hello hello after a bit of help
So i got some wheel bearing kits for the front of my 1974 disk brake 120y #2842 and they are too big ,my stub axle is smaller. unfortunately the number has worn off the small outer bearing. i did a little search and i think i need #2841 however some listing's state this is for drum brakes? anyone able to shed some light?
Thankyou Thomas
Posted on: 2016/2/14 8:42
Re: 120y front wheel bearings
* 1974-1975 120Y has small axle stubs, same as B110
* 1976-1978 120Y has large axle stubs, same as 1976-up 1200 ute
For the early 120Y/B110 the wheel bearings are:
* INNER: 52 mm O.D. Type 30305
* OUTER: 42mm O.D. Type 30302
Same bearings used by disc or drum
For specific part numbers see our Wheel bearings tech article
Posted on: 2016/2/14 9:14
From Sydney
cheers ddgonzal
Posted on: 2016/2/14 9:25
