« 1 (2) 3 »
Re: H165 LSD
From Creswell, Oregon USA
So will a Murano R145 LSD fit a H145 case and saddles?
Posted on: 2016/2/24 0:54
Re: H165 LSD
From Port Douglas. QLD
Ill be selling my top gear lsd soon. Its only done a very easy 5000km. Have purchased an r31 diff with lsd.
And yeah they are good!
Posted on: 2016/2/24 1:17
1200 ute
ca18det
Re: H165 LSD
From Hawaii, USA
Not that I know of. The R145 is made by Fuji, and the H145 by Hitachi. If anyone (like D) is thinking of switch to R160 from a 510/610/Subaru, consider the R145 instead
If you have a CA18DET, the R31/Borg-Warner is a better choice. The Chevrolet guys here like them
Posted on: 2016/2/24 2:53
Re: H165 LSD
From Adelaide
Re the H145 for cloning, we have a 3D scanner at work, that would be the quickest/ easiest way to model up the parts. I'm sure there's someone closer to you that could do the same. The high end scanners can measure as good or better than standard metrology.
Posted on: 2016/2/24 8:05
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: H165 LSD
If anyone needs any CAD work done, let me know, I'm a CAD guy by trade.
3D scanning would be helpful if possible so long as it's high enough resolution, but obviously not required if the part is available to take measurements off.
Posted on: 2016/2/24 8:31
Re: H165 LSD
From Warburton vic
I've got an h165 open diff. It's going to be behind a cammed up SR N/a. The h165 is to small so I don't want to spend the dollars going for the clutch pack style LSD. I'm going to do the hilux conversion with a trutrack & full floater axles. Iwas thinking about the traction concepts as a cheaper & temporary option. I was just wanting some feed back on them.
Posted on: 2016/2/24 20:59
Re: H165 LSD
From Hawaii, USA
It is a true LSD (providing Limited slip). There are various types of LSD (including gear, clutch, viscous) and this is another type. It may not be the best but it works. Remember that the factory H165/H190 LSDs are also considered "cheap" and not long-lasting
* Those who haven't used them don't like them
1200rallycar: i've had mine for probably a year and shes still going stong, #### its only $100 or 150 to renew it all after its been done a first time anyway
supafatto: Depending on how you drive a phantom can last for a long time, to my memory mic had it in a rally car for 2 years then I had it in a road car for bout the same and at the end it started slipping but just needed to be re shimmed.
Posted on: 2016/2/24 22:31
Re: H165 LSD
From Criminal Pig free land
""Remember that the factory H165/H190 LSDs are also considered "cheap" and not long-lasting - * Those who haven't used them don't like them""
Hahaha thats very true!
Posted on: 2016/2/25 14:14
"Australia" means the Commonwealth of Australia and, when used in a geographical sense, includes Norfolk Island, the Territory of Christmas Island and the Territory of Cocos (Keeling) Islands, but does not include any other external Territory.
Re: H165 LSD
Not too shy to talk
From Tauranga,N.Z
Quick question... will all H165 lsd heads fit into 1200 ute H165 housings? or can you just use the H165 lsd unit and stick it into the ute non lsd carrier?
Posted on: 2016/2/27 4:23
Re: H165 LSD
From Mordialloc Victoria 3195
Posted on: 2016/3/2 5:39
keep it simple
« 1 (2) 3 »
