#11 Re: Datsun 1200 Ute
screamingeagle Posted on: 2016/3/1 11:28
Doesnt look physically damaged, looks old, but it has been cut into for central locking and speakers in the doors....
Today, I found there is power at the switches once turned on for lights, wipers etc... I go and check for power at the connections to the wiper motor, washer, etc and there is none. I have cleaned all connections to each of th above.
Can someone please tell me if to cut the harness up and replace the wiring or if to get a another harness, prolem is I could end up with another harness with broken wires!!
I have checked all relays and when powered they tick so they are ok.
Appreciate some imput guys.
Thankyou!
#12 Re: Datsun 1200 Ute
ddgonzal Posted on: 2016/3/1 21:01
Broken wires are very rare. Most commonly is the cause is never figured out, and chalked up to some mysterious casue
If it is one problem, like on my ute, the Temp Gauge wire never worked, so I just ran one new wire from the engine and spliced it into the dash loom
If it is many things, better to find the cause or replace the loom
Ute dash loom comes in several versions:
HARNESS ASSY-INSTRUMENT/Instrument Harness Cable 24013
24013-H1002 (up to '73-3)
24013-H1022 (up to '71-3) (op.)
24013-H1206 (up to '71-4)
24013-G1000 73-74?
24013-G1602 -7803
24013-G1661 7804-8109
24013-G1900 8110-8608
« 1 (2)
