Re: 78 120Y coupe
From Brisbane, Australia
Fitted the King springs to lower the front. Also did the same castor mod as the 2dr sedan - moved the castor boxes forward 20mm by drilling 4 new holes and cut 20mm off the front. It drove so much better on the wide rubber with the extra castor, I had to do it to this one as well.
Lipped the front guards and trimmed the front lower corner of the wheelarch to clear the bigger, wider tyre with the extra castor pulling it forward.
Flipped a rear leaf to lower the back about 3". I'll need to trim the bump stops and extend the lower shock mount to get some travel back, but I'm happy with that ride height. The front will come down another 30mm with a pair of 1200 strut tops.
Posted on: 2016/3/5 9:50
Edited by L18_B110 on 2016/3/5 23:39:00
Subject Poster Date
     78 120Y coupe L18_B110 2013/2/23 1:40
       Re: 78 120Y coupe Anonymous 2013/2/23 1:45
       Re: 78 120Y coupe Bluemax 2013/2/23 1:45
       Re: 78 120Y coupe b310gx 2013/2/23 8:02
         Re: 78 120Y coupe trb012 2013/2/23 9:50
           Re: 78 120Y coupe L18_B110 2013/2/23 22:16
       Re: 78 120Y coupe L18_B110 2013/2/28 11:24
         Re: 78 120Y coupe Anonymous 2013/2/28 12:11
       Re: 78 120Y coupe SunnyDaze 2013/3/1 0:37
         Re: 78 120Y coupe L18_B110 2013/3/1 2:54
           Re: 78 120Y coupe L18_B110 2013/5/22 2:19
       Re: 78 120Y coupe L18_B110 2016/2/28 22:07
         Re: 78 120Y coupe L18_B110 2016/2/28 22:23
           Re: 78 120Y coupe zigmondo 2016/2/28 23:35
             Re: 78 120Y coupe L18_B110 2016/2/29 0:40
               Re: 78 120Y coupe D 2016/2/29 3:56
                 Re: 78 120Y coupe L18_B110 2016/2/29 5:29
                   Re: 78 120Y coupe D 2016/2/29 11:01
                     Re: 78 120Y coupe Anonymous 2016/2/29 12:45
                     Re: 78 120Y coupe D 2016/3/1 13:18
       Re: 78 120Y coupe L18_B110 2016/2/28 22:12
       Re: 78 120Y coupe L18_B110 2016/3/2 23:50
       Re: 78 120Y coupe L18_B110 2016/3/2 23:53
         Re: 78 120Y coupe D 2016/3/3 4:48
           Re: 78 120Y coupe Anonymous 2016/3/3 5:40
             Re: 78 120Y coupe L18_B110 2016/3/3 23:35
       Re: 78 120Y coupe D 2016/3/4 0:17
       Re: 78 120Y coupe L18_B110 2016/3/4 3:54
       Re: 78 120Y coupe L18_B110 2016/3/5 9:50
       Re: 78 120Y coupe L18_B110 2016/3/5 23:43
       Re: 78 120Y coupe MYB110 2016/3/6 0:39
       Re: 78 120Y coupe D 2016/3/6 1:24
       Re: 78 120Y coupe L18_B110 2016/3/6 4:15
         Re: 78 120Y coupe Anonymous 2016/3/6 5:43
       Re: 78 120Y coupe b310gx 2016/3/7 8:47
         Re: 78 120Y coupe Anonymous 2016/3/7 9:04
           Re: 78 120Y coupe L18_B110 2016/3/7 23:47
             Re: 78 120Y coupe Anonymous 2016/3/8 6:17
       Re: 78 120Y coupe b310gx 2016/3/8 8:59
         Re: 78 120Y coupe D 2016/3/8 13:13
           Re: 78 120Y coupe L18_B110 2016/3/9 4:55
             Re: 78 120Y coupe L18_B110 2016/3/21 21:37
       Re: 78 120Y coupe L18_B110 2016/3/10 21:39
       Re: 78 120Y coupe L18_B110 2016/3/13 3:19
         Re: 78 120Y coupe Anonymous 2016/3/13 8:50
       Re: 78 120Y coupe L18_B110 2016/3/19 9:03
         Re: 78 120Y coupe L18_B110 2016/3/20 0:05
       Re: 78 120Y coupe b310gx 2016/3/22 8:27
         Re: 78 120Y coupe L18_B110 2016/3/22 9:28
       Re: 78 120Y coupe L18_B110 2016/3/28 10:51
       Re: 78 120Y coupe L18_B110 2016/3/28 11:05
         Re: 78 120Y coupe Anonymous 2016/3/28 12:49
       Re: 78 120Y coupe b310gx 2016/3/29 9:25
       Re: 78 120Y coupe L18_B110 2016/3/29 22:52
         Re: 78 120Y coupe ddgonzal 2016/3/30 4:49
       Re: 78 120Y coupe L18_B110 2016/3/30 5:28
       Re: 78 120Y coupe L18_B110 2016/5/9 9:43
       Re: 78 120Y coupe L18_B110 2016/5/11 9:19
         Re: 78 120Y coupe L18_B110 2016/5/11 9:22
       Re: 78 120Y coupe L18_B110 2016/5/13 8:00
         Re: 78 120Y coupe Anonymous 2016/5/14 1:30
           Re: 78 120Y coupe L18_B110 2016/5/14 2:37
       Re: 78 120Y coupe b310gx 2016/5/14 5:09
         Re: 78 120Y coupe D 2016/5/15 3:25
       Re: 78 120Y coupe b310gx 2016/5/15 6:27
         Re: 78 120Y coupe L18_B110 2016/5/16 5:04
           Re: 78 120Y coupe D 2016/5/16 8:52
             Re: 78 120Y coupe Mawler1 2016/5/18 6:08
               Re: 78 120Y coupe L18_B110 2016/5/18 10:23
               Re: 78 120Y coupe Mawler1 2016/5/18 11:51
       Re: 78 120Y coupe L18_B110 2016/6/20 0:30
       Re: 78 120Y coupe b310gx 2016/6/20 9:22
       Re: 78 120Y coupe L18_B110 2016/7/3 9:49
       Re: 78 120Y coupe b310gx 2016/7/4 8:04
       Re: 78 120Y coupe L18_B110 2016/7/4 9:05
         Re: 78 120Y coupe D 2016/7/5 7:12
           Re: 78 120Y coupe L18_B110 2016/7/5 10:29
             Re: 78 120Y coupe D 2016/7/5 16:12
       Re: 78 120Y coupe L18_B110 2016/7/9 4:12
         Re: 78 120Y coupe Anonymous 2016/7/9 4:46
           Re: 78 120Y coupe L18_B110 2016/7/10 3:51
       Re: 78 120Y coupe b310gx 2016/7/11 10:24
         Re: 78 120Y coupe ddgonzal 2016/7/11 10:39
           Re: 78 120Y coupe L18_B110 2016/7/12 0:33
             Re: 78 120Y coupe ddgonzal 2016/7/12 2:28
       Re: 78 120Y coupe L18_B110 2016/7/12 4:01
       Re: 78 120Y coupe L18_B110 2016/7/14 0:35
       Re: 78 120Y coupe b310gx 2016/7/14 10:04
         Re: 78 120Y coupe L18_B110 2016/7/14 23:41
           Re: 78 120Y coupe L18_B110 2016/7/15 8:28
             Re: 78 120Y coupe L18_B110 2016/7/17 1:38
               Re: 78 120Y coupe ddgonzal 2016/7/17 6:35
                 Re: 78 120Y coupe L18_B110 2016/7/18 12:25
                   Re: 78 120Y coupe ddgonzal 2016/7/18 21:57
                     Re: 78 120Y coupe L18_B110 2016/7/18 23:47
       Re: 78 120Y coupe L18_B110 2016/7/25 1:14
         Re: 78 120Y coupe ddgonzal 2016/7/25 7:31
       Re: 78 120Y coupe b310gx 2016/7/25 8:45
         Re: 78 120Y coupe Anonymous 2016/7/25 10:13
           Re: 78 120Y coupe L18_B110 2016/7/26 9:30
             Re: 78 120Y coupe nismo 2016/7/26 10:45
       Re: 78 120Y coupe SunnyDaze 2017/12/7 0:08
       Re: 78 120Y coupe L18_B110 2017/12/7 1:53
         Re: 78 120Y coupe SunnyDaze 2017/12/7 6:18
       Re: 78 120Y coupe L18_B110 2017/12/11 23:55
