Its all interesting and I like the idea of the throttle where it is
to avoid using carbon sealed old turbos and instead use BB beauties.
Im just wondering if those bends werent there would response be better
and still make the same hp? will prob never know but I remember some1
saying for a drawthrough setup the shorter the distance the flow with
the charge needs to travel the more hp and the better the response.
Just theoretically if those bends werent there so atomised fuel has
a more direct passaged from turbine into the head even with 26mm id
manifold would the response be improved especially with high psi?
Lets say the inlet manifold has the ideal ID so increased mani capacity
but without the big 42mm tubing its using atm and instead the compressor
feeds this inlet manifold more directly like a shorter version of this mani
http://www.maniflow.co.uk/uploads/617 ... 321b1213733751e926350.jpg
to some factory datsun A12 GX twin SU manifolds instead.
Wouldnt that get PSIs faster than this current setup therefore be more
responsive yet make just as much or more hp?
