« 1 2 3 (4) 5 »
Re: A12 in a 1964 MG Midget
That's a difficult one. You can find it on a 1971-1973 Datsun 1200
As far as I know only that plus Datsun 1000 (which was never sold in USA) used it
* 30422-18000 COVER-DUST CLUTCH HOUSING B10, B110
* 30422-H5010 COVER-DUST CLUTCH HOUSING B110 0473-
If you are using a newer transmission (1974-up), use the full engine plate instead + the short release bearing sleeve
jpg  17598.jpg (9.12 KB)
174_56e6747185a50.jpg 200X112 px
Posted on: 2016/3/14 8:21
Not too shy to talk
I'm guessing no one makes a reproduction? I guess I wouldn't be that hard to make one.
Posted on: 2016/3/17 4:05
So you'll be reproducing them? No one has asked about this part in many years, so there appears to be no demand ...
Posted on: 2016/3/17 5:17
Not too shy to talk
Not mass produced, just one for my engine. It seems pretty important to properly cover the transmission with the clutch, flywheel and throw-out bearing being exposed without the cover.
Posted on: 2016/3/17 5:42
Not too shy to talk
Does anyone have a good source for piston rings? I see that RockAuto does not carry them and I don't really know where else to look. There is an NOS set on eBay but is it a good idea to use 40 year old replacement rings?
Posted on: 2016/3/21 16:26
Rings are made out of Cast Iron and the oil control rings are steel. They usually don't go on the shelf unless they rust
Nissan 12033-H6201 No Longer Available
eBay http://www.ebay.com/itm/12033-H6200
A12 Forklift Rings
Classic Garage HA-6714STD
Riken Rings
Posted on: 2016/3/22 1:31
By the way, original equipment was Riken RIK-vent rings
Here's another: Hastings 2C6714 $37 set
Posted on: 2016/3/22 2:18
From Las Vegas USA
I almost forgot about this post but I Amy have a couple of extra clutch cover plates. I'll check and let you know tomorrow.
Tom
Posted on: 2016/3/22 4:51
From sydney australia
clutch dust covers almost the same as these (have larger holes across the bottom) can be found on B310 automatics. They have the larger holes for the 3 10mm bolts across the bottom of the 60 series transmissions, as opposed to the 6mm bolts used in the 56 series transmissions. Hope this helps a little.
Posted on: 2016/3/22 8:12
Not too shy to talk
Well, I busted the rear circular flange of the transmission case trying to get the output shaft seal out. There's a welder in town who can weld cast aluminum but that's this week's sob story. However, I have the engine mocked up in the car to make new mounts during the next two days. The dual SU carburetors look great!
Posted on: 2016/3/24 6:08
« 1 2 3 (4) 5 »
