Upgrade Datsun 1200 Front DIsc Brake
From Lisbon
Hi!
I want upgrade my Datsun 1200 front brake discs, i dont want push the wheel out than standard. Actualy i have upgrade the engine and i want better brakes. My actual wheels 6.0 x 13 Minilite Mag Style / Bolt - On 4x114.3 ET +12.
All i want is a bigger rotor and a better brake caliper
Please advice me
Man thanks
Luis
Posted on: 2016/4/19 21:51
Re: Upgrade Datsun 1200 Front DIsc Brake
Perhaps best swap is:
* 1200 drum hubs
* S13 rotors (250mm) & calipers
This combination keeps Track exactly the same, with no machining required. Only need the caliper adapters. See S13 brakes
The only thing is that some 13" alloy rims will fit 250mm brakes, but steel wheels will not. And some alloys won't fit either
Posted on: 2016/4/20 11:00
The 250 mm rotors may not be available in Europe?
Other swaps for bigger rotor & caliper:
* 251mm 280ZX swap (with drum hubs). See 280ZX Brake Upgrade
* 245mm B310 140Y/150Y rotor swap, also has larger calipers -- fits 13" wheels. See Big Disc Upgrade
Posted on: 2016/4/20 11:10
From Lisbon
Many thanks
I will search S13 250mm rotors and calipers on ebay. (4 studs 114.3 pcd, it is possible find new or in good shape brake calipers?)
I will need help from caliper adapter. i dont need to buy anything like ball joint, ball stud idler arm
Please see if im thinking ok
http://www.ebay.com/itm/1989-1994-Nis ... :ZtcAAOSwUuFWzRp~&vxp=mtr
They are correct for my Datsun 1200?
OR
http://www.ebay.com/itm/JDM-NISSAN-SI ... :WWsAAOSwfZ1WaohK&vxp=mtr
Luis
Posted on: 2016/4/20 13:44
Edited by Luigi on 2016/4/20 14:05:11
Edited by Luigi on 2016/4/20 17:16:29
Edited by Luigi on 2016/4/20 17:25:41
Edited by Luigi on 2016/4/20 20:59:56
Edited by Luigi on 2016/4/20 21:03:54
Quite a regular
From Aberdeen, UK
the bottom ones r bigger than standard s13, I have used them as an upgrade on my s13 :D
You should try the sx owners clubs, boys r always upgrading their s13s so you can get them cheap and quite often in good nick. Maybe even some of the SXOC uk guys will post out to you.
Posted on: 2016/4/20 22:20
From Lisbon
Many thanks for forum ideia.I will register and find it
Posted on: 2016/4/20 22:48
In EUR and USA, we didn't get 250 mm rotors, we got larger 257 mm which won't fit 13" wheels
the 245mm are the only ones that fit most 13" wheels
Posted on: 2016/4/20 23:19
Yes, these listed as "JDM Nissan Silvia S13" are not ... they are R33 or something. Will they fit within 13" wheels? Unknown
jpg  s-l1600.jpg (156.38 KB)
174_571801374635c.jpg 1280X960 px
Posted on: 2016/4/20 23:22
These listed as "Nissan 240SX" are USA S13, so are for the 257 mm rotors. Maybe the same as JDM or Australia 250 mmm calipers, maybe not
jpg  240SX.jpg (104.84 KB)
174_571802423c71e.jpg 1278X640 px
Posted on: 2016/4/20 23:27
From Lisbon
Please advice me one brake caliper and 245 or 250mm rotor to fit my std struts and 13 whells and a bracket
Many thanks on advance
Luis
Posted on: 2016/4/21 22:32
