Browsing this Thread:
1 Anonymous Users
Re: E--supercharger |
Registered Users Contentmaster Usermaster
Yes, the Nissan Leaf will never work ...
Posted on: 2012/12/20 21:29
Leaf is fantastic, even has patented guard shape that removes air turbulence from side mirrors, but the result of the whole car is undoutedly ugliness. If they designed it away from weird and used a different name rather than Leaf or like Mitsu did with theirs, there you go cant even remember it! would have help.
Sad considering Nissan had some awesome sought after retro cars in the past.
All battery is good thats no question but ICE and electric supercharger and heaps of batts is like taking the Prius and adding electric supercharging. The volt is a better idea as long as it doesnt add e-SC :)
Posted on: 2012/12/21 0:55
From Christchurch NZ
Brushless motors are getting pretty good nowdays. But for 99% of applications it's a wet dream. Screw chargers are tons more effeicent than roots. So there's sh1tloads less parasitic loss. I'll be sticking with my belt driven pumps for the moment thanks.
Posted on: 2012/12/22 5:00
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
Re: E--supercharger -- dyno result |
Looks like we were all wrong ... strongest run was with the electric blower: Quote: sikyne: He is a dyno graph showing three runs.. One from Lagwagon's A12, One from Ange's and the highest run was when we used an electric blower to force feed it!
One thing we forgot is that for acceleration, the electricity can come out of the battery, so no load is put on the engine ... then the battery can be recharged when cruising
Posted on: 2016/5/27 0:38
From Brisbane, Australia
I would have thought F1 would be a better example than a leaf blower :P
Posted on: 2016/5/27 3:54
I agree the battery CAN be recharged at cruise, so that AT BEST relegates the idea to drag racing, or the occasional/emergency overtaking manouever. It'd also be interesting to see that dyno graph if the motors were run for more than say, 15-20 seconds (guesstimate admittedly, and I know sikyne is absolutely 100% integrity, the graphs and data are legit, no argument or aspersions there) of the dyno pull, as wiring starts to heat up and battery drains and all the rest. the power will almost certainly drop off. If the application doesn't require it then that's no issue whatsoever, but even with some very fast cars I've had over teh years, i've (and obviously this means I'm admitting to driving illegally and I don't endorse it nor am I proud of it, but it is what it is) run cars at full throttle for approaching a minute, and then with a short term let off, back on the throttle and so on. If 'that' is what the app requires, belt or exhaust gas driven is still going to destroy it.
THe McCulloch/Paxton blowers seen on studebakers and also available as kits in the 50s or thereabouts used a fairly primitive compressor wheel/housing design to be sure, but they also had a variable drive. It wasn't adequately reliable when pushed beyond stock/intended applications/boost levels but nonetheless showed promise, and I wonder if a modern take on it might have some potential.
Obviously stuff like lysholm compressors absolutely are a considerable cut above a rootes type but that in and of itself is sort of secondary to the drive method imo. don't get me wrong, I think it has application, particularly in some sort of hybrid/combination situation where it can be used to create boost off idle or similar, but there's still usefullness in the relative simplicity and know quantity of engine or exhaust gas drive.
Posted on: 2016/5/27 14:52
John McKenzie
From RSA
geez jmac what made you bring this up.[nice tests by sykine] Are you also looking at the pros and cons?This was a write up i saw in jap mag [tech talk]which i found quite interesting.I am now reading another interesting article about throttle bodies [intake] If i get time i might put it up here eg different types of throttle body, what is a t/body, throttle diameter,inlet length,butterfly and injector positions,taper or parallel body,inlet trumpets,spindleless throttle types,turbocharging t/bodies ---might be in time for those making their own intakes
Posted on: 2016/5/27 18:39
Hey Jmac's back. (I don't get on here much anymore) Hope your health is playing ball now?
Posted on: 2016/5/29 9:47
Quote: THe McCulloch/Paxton blowers seen on studebakers and also available as kits in the 50s ... I wonder if a modern take on it might have some potential. Paxton blowers are quite popular in my country http://www.summitracing.com/search/brand/paxton-automotive-corp
Posted on: 2016/5/30 8:50
They certainly work, but they a: are less efficient than either rootes or particularly twin-screw lysholm superchargers, and b: make less boost throughout their range until fairly high rpm because they're not positive displacement. If you want your power over 4000 rpm, an axial or centrifugal compressor works well (but if so, why not use a turbocharger?) If you want it off the line, you probably will be more satisfied with an Eaton supercharger off a Mini or something.
Posted on: 2016/5/30 18:34
