« 1 (2) 3 »
#11 Re: Calculating compression ratio
ddgonzal Posted on: 2016/1/11 23:37
if I use a centered dish piston will my compression go up?
I'm thinking it will go down, but it depends on which centered dish piston you use. USA offset-dish and non-USA offset-dish differs.
#12 Re: Calculating compression ratio
ddgonzal Posted on: 2016/1/11 23:50
Ross will make you a set of flattops for about $400/set. Give you 10.9:1 with a standard head gasket. Requires Premium or E85 fuel, but will return better fuel economy so it ends up fuel costs are the same.
A15 Piston
* Three different factory A15 centered-dish pistons
* 2 or 3 different factory A15 offset-dish pistons
#13 Re: Calculating compression ratio
TexasMidget Posted on: 2016/1/15 17:35
Ok guys. I got a more accurate syringe at a feed store and its in ml which is equivalent to cc. Measured it several times. GX head is 28 ml/cc and the piston dish is 13 ml/cc. Can someone run the numbers for me? I really prefer not to use premium gas if I dont have to. But DD makes an interesting point that if I have higher compression it will get better fuel economy which makes it a wash.
You guys may notice I am a novice at all this but slowly picking up alot along the way and will be better prepared for my next build. I have worked on a variety of automobiles for many years but not with the technical components (cam lift/duration, compression etc) of an internal combustion engine. You all must be engineers.......
#14 Re: Calculating compression ratio
Rallytwit Posted on: 2016/1/16 4:59
Use the link on the first page that Thaifrog provided; I checked and using the standard felpro head gasket you are looking at 9-1 compression ratio. If you go to the .6 thick head gasket you are looking at 9.5-1
Tom
#15 Re: Calculating compression ratio
TexasMidget Posted on: 2016/1/16 5:31
Thanks Tom. I can still use regular unleaded fuel with that ratio?
#16 Re: Calculating compression ratio
ddgonzal Posted on: 2016/1/16 6:42
Yes, 9:1 was the standard USA compression ratio for 1971, and spec'd for 87 R+M/2 Octane.
If you go with an open combustion (type C) it might ping or run-on, but with the closed chamber (type A/B), no worries
#17 Re: Calculating compression ratio
TexasMidget Posted on: 2016/6/22 4:22
Block is being decked 5 thousandths and GX head was shaved 5 thousandths. Any idea what my compression ratio will be? Piston dish is 13ml/cc and GX chamber was 28ml/cc prior to shaving.
#18 Re: Calculating compression ratio
ddgonzal Posted on: 2016/6/22 4:36
This CR calculator will tell you: http://www.csgnetwork.com/compcalc.html , you'll need to measure the head CCs again. For a rough estimate, subtract about 1/2 of 5/1000" from the gasket thickness
#19 Re: Calculating compression ratio
Rallytwit Posted on: 2016/6/22 4:37
I can't remember what motor you have in the car but somewhere between 8.6 and 9.1 dependent on A14 or a15.
Tom
#20 Re: Calculating compression ratio
ddgonzal Posted on: 2016/6/22 4:42
Previous estimate for his engine was 9:1 to 9.5? ... CR will be higher after shaving the head and block
« 1 (2) 3 »
