« 1 ... 7 8 9 (10) 11 »
Re: 78 120Y coupe
From Brisbane, Australia
Thought I'd take it for a run this morning over Mt Glorious, but it has decided since Friday that it no longer wants to go into reverse! So I pushed it out of the garage (it's uphill - took two goes to get it over the hill lol) and off I went. It drove great, handles well, temp is no problem up the steep mountains, but it wouldn't shift into 5th either... Bloody thing was perfect when I drove it to work on Thursday and tuned it up Friday arvo. Now refuses to go into reverse or 5th. Oh well, I have a 71B 5spd in the shed - 3rd time lucky hopefully! lol
Posted on: 2016/7/17 1:38
Re: 78 120Y coupe
sounds like the shift fork pin sheared or came out. Might be an easy fix?
Posted on: 2016/7/17 6:35
Re: 78 120Y coupe
My old mate Rob aka Datsun Yoda asked if I had the right shifter in it. Seems these boxes are fussy about the gate locations and some shifters are slightly longer under the pivot point moving it too far. Put the old straight shifter in and all good again.
Feeling a little silly but relieved! lol
Posted on: 2016/7/18 12:25
Re: 78 120Y coupe
Thanks for sharing that tip, I hadnt heard of it
Posted on: 2016/7/18 21:57
Re: 78 120Y coupe
yeah, me either! I don't understand how it was all fine last Thursday when I drove to work, then just stopped working. Whack another gear stick in and it's all good. But I'll take it!
Posted on: 2016/7/18 23:47
Re: 78 120Y coupe
I did about 600km in the 120Y on the weekend. Went up the coast on Saturday morning to pick up an inlet manifold for it, then on Sunday I took it for a run down the Mt Lindesay Hwy. This is how it sits now after the L series conversion, withthe heavier 260Z front springs and extra leaf in the back:
It ran great. My only complaint is the exhaust is too loud. I'll have to change the muffler to something quieter. Goes much better in the hills than it did with the A14 , and much nicer to cruise along at 110km/h at 3300rpm rather than 4000rpm with the A series 4 spd!
Posted on: 2016/7/25 1:14
Edited by L18_B110 on 2016/7/25 2:42:49
Re: 78 120Y coupe
nice stance, like a bullet
Posted on: 2016/7/25 7:31
Re: 78 120Y coupe
From sydney australia
'Its too loud, I'll have to make it quieter'. I know how you feel, Harry, my Sunny Coupe is used as an alarm clock by the entire suburb, when I drive it to work. It also destroys the car as a tourer. But, when we were young & stupid, the noisier the better. I like Quiet & Quick, for the street, it's a lot less expensive in fines. I'm really starting to get motivated now.
Are you getting a SSS carby set up together for it? I've always had a thought on how you'd use a throttle quadrant for the cable, instead of the rods from the firewall. If you'd like. I'll try & figure it out, then give you a yell.
PS Time for an avatar change? maybe.
Posted on: 2016/7/25 8:45
Re: 78 120Y coupe
Looks great. So you're bored of it and want a faster one already. Sell sell
Posted on: 2016/7/25 10:13
Re: 78 120Y coupe
I have a set of SSS round top Hitachis complete with factory air filter assembly, but it won't fit with these extractors. I also have a Lynx crossover single sidedraught manifold and a pair of 40mm Dellortos, but I wouldn't bother with a sidedraught unless I got a bigger cam as well, but a cam grind costs as much as the shift kit I want for the Soarer to make it faster at the hillclimb. Whereas the cam for the 120Y is just to make it cooler really, so that's not going to happen for a while - too many cars and not enough money to go round!
I would like to upgrade the Delica to another Patrol too, but I'd have to sell the Delica and another car to do that - so selling the Datsun is not totally out of the question... Particularly if it goes to someone from here where it will have a good home. Maybe I like building them more than living with them? lol But I do like it. I drove it to work again today, just because. It really turns heads :)
Posted on: 2016/7/26 9:30
