« 1 (2)
Re: EFI for under $1000
From Creswell, Oregon USA
I will put this in my build thread.
Posted on: 2016/8/26 21:05
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
Yes, makes more HP than the stock carburetor. The Excel throttle body flows more air, bigger than a Weber 32/36 upgrade. Smoother and more fuel efficient than any carburetor
Stock unmodified manifold
bolt on the Excel throttle body (comes with a TPS unit) about $30 used. bolt on the Lancer fuel regulator ($9 pick-n-pull, $35 new). Bolt on the used Nissan injector ($7 at pick-n-pull)
New EFI computer ($400 USD, $500 AUD) with plenty of potential for future upgrades including multiple injectors and coil packs, even turbo if you want
Add a Carter 60 psi fuel pump $79 and a return line of standard fuel hose, Tee into the fuel filler hose
Posted on: 2016/8/27 2:35
stock mani is restrictive for any carb or efi setup
and for 1000 clams better go DT carbed turbo
EFI even on todays most advanced Ford 4.6 engines
with factory tuned efi struggle vs Carbed setups
http://www.musclecardiy.com/cylinder- ... et-cylinder-heads-part-5/
All depends what you want but carbs are still not that bad
for economy and overall decent performance if you just make sure
your engine is healthy, higher comp and slightly larger capacity
if its getting either a freshen up or full rebuild
The single injector setup shown above had flat spots
Posted on: 2016/8/27 7:06
Yes, he had flat spots when using E85 and unheated manifold. The stock manifolds are all heated, so it shouldn't be a problem
Yes, racing carburetors beat factory EFI, no doubt. Only when you get to the level of performance EFI does it win out
* A14 factory carbureted: 80 HP
* A14 factory EFI: 92 HP
* 1965 Corvette 327 factory 4BBL carb: 365 HP
* 1965 Corvette 327 factory fuel injection: 375 HP
Yes, this budget EFI is not a high performance option. It runs smooth and efficient, but if you're looking for big power a turbo is the best bang for the buck
This manifold and throttle body made 127 HP with turbo on sikyne's dyno
Posted on: 2016/8/27 7:29
Edited by ddgonzal on 2016/8/27 7:47:47
The EFI setup using stock manifold has an estimated cost of $632 USD total not including tax & shipping
Add to that cost of tuning:
* DIY: $181 new A/F gauge, wideband controller & Bosch LSU4.9 sensor
or
* $ ??? engineer & dyno time
or
* Old-school experts can tune by ear. Cost $0
Posted on: 2016/8/27 8:33
A stock carb setup for stock A series is quite formidable as well
there are plenty of ways to make the stock carbed A series very
smooth with little tricks like indexing spark plugs and my fave
a heavier flywheel than stock increases economy and driveability
in all street rpm ranges. Electronic ignition and once is a while
spray h20 into a warmed up running engine to clear carbon deposits
As an experiment after owning a 2cv used a custom billet flywheel
made for speedway! that came with some parts I bought in a lot
and fitted to an high comp stock A12 you couldnt stall it
and climbed hills like it was an L series.
It was like a momentum energy storage device!
Few credit how silky smooth driving is with a heavier fly
The EFI manis for the A series flow more than the stock carb manis
and rowland manifolds make a nice setup for 38/38 as well and
Ive seen an SU adaptor to a similar manifold to suit 2 inch SU
which could flow more than stock and match efi hp ratings
Posted on: 2016/8/27 9:10
« 1 (2)
